5183 Discussions
No usable memory found - Server board
pvish
I trying to assemble my workstation at home.
The motherboard is S2600cP2,
The CPUs are E-2620 V2 (dual)
Memory Modules are kvr13lr9d4/16ha
When i try to powerup the machine it boots up with the following message with 3 beeps
Installed BIOS: SE5C600.86B.01.08.0003
Platfrom ID: s2600CP
No usable memory found.
Is this issue related to the
lower BIOS version/ Due to the CPUs which might require a bios upgrade.
or
Incompatible DDR3 memory.
Vishnu
Edward_Z_Intel
More likely it's the memory.
BIOS 01.08.0003 should be able to boot a Xeon E5-2600 V2 processor, although BIOS 02.01.0002 is needed for the CPU to be fully functional.
It's highly recommended that you select memory (and other hardware accessories) from the http://www.intel.com/support/motherboards/server/sb/CS-033388.htm Memory and Hardware Compatibility list.
