Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
5228 Discussions
PCIe MMIO Poor Access Performance
Shunyu
I'm testing my FPGA with PCIE4.0 X16 on Intel Xeon 6438Y+, the theoretical bandwidth is 32 GBps per direction. If I use DMA method to perform access, it can be achieved to 27GBps, which is quite reasonable. But when I try to use MMIO via UIO to access BAR space, the highest bandwidth is only 3.75 GBps.
I have tried consecutive vmovntdqa, vmovapd, movdir64b, memcpy(), and I use ioremap_wc() in kernel driver to map a 4MB Write Combine space.
NormanS_Intel
Hello Shunyu,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Server Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Norman S.
Ragulan_Intel
Hello Shunyu,
Greetings!
As pertaining to the query you have, kindly reach out to the FPGA community and post question on the appropriate subforum topic.
Intel Community - FPGAs and Programmable Solutions
Thank You & Best Regards,
Ragulan_Intel
