5173 Discussions
Problem lasted version of Intel Matrix Storage on SBS 2008
kmary
Hi everyone ! I've a problem to run Intel Matrix Storage on my server SBS2008. When I run the setup, I've a message eror " OS is not supported"
but he is compatible with Windows server 2008. I've manually installed the driver and he works. Actually my server works and my RAID is OK. But now,
I can't have my Interface Management RAID on my server. It's very dangerous.
Could you help me please ?!
Many thanks !
David_A_Intel
You might want to check if .Net Framework 3.5 is enabled for your Operating System. You can check the steps http://blogs.msdn.com/b/sqlblog/archive/2010/01/08/how-to-install-net-framework-3-5-sp1-on-windows-server-2008-r2-environments.aspx here on how to enable it.
Please include the model of your system board and the driver version you are using.
kmary
Thanks for your answer david. I'll update my server. that works with Intel Matrix Storage 11.7 .
Many thanks.
