5181 Discussions
Rails on Intel Server P4308CP4MHEN
KKlem
Hi there,
I have a P4308CP4MHEN Intel Server System that I would like to put in a rack, do I need anything else than Enhanced Value RAIL AXXELVRAIL?
Klemmi
SBlitz
New Contributor II
Yes, you need a full kit (see config guide here - http://www.intel.com/content/www/us/en/support/server-products/server-chassis/000006940.html Spares, Parts List, and Configuration Guide for the Intel® Server... )
There is rail kit, rack-able front door and front bezel.
Good luck.
SBlitz
New Contributor II
Good luck.
The information provided by forum user Saarblitz is correct. You will need either one of the conversion kits (AXXELVRAIL, AXX3U5UPRAIL) along with the door&frame (AUPBEZEL4UD&AUPBEZEL4UF).
KKlem
Thank you both Saar and Intel Corp for your quick and informative replies!
Have a great day!
