5175 Discussions
Random reboot of server system SR2625URBRP
i have problem with random reboot of server w2k8 64bit.
When i try reinstall OS, the server reboot by first screens.
Configuration:
Server system SR2625URBRP
CPU 2x Intel Xeon E5520
RAM 6x 4GB KVR1066D3Q8R7S/4G (blue sockets A1,B1, C1, D1, E1, F1)
RAID SRCSASBB8I
HDD 4x SAS ST9146802SS, 2x SATA ST9500420AS
Redundant power
BIOS S5500.86B.01.00.0054
BMC 0.54
HSC 2.16
ME 1.12
SDR 13.20
Raid FW 1.40.92-0746
SEL: Memory # 0x02 CRITICAL event: Memory sensor 2 reports uncorrectable error. There has been an uncorrectable ECC or other uncorrectable memory error for the memory module CPU_2, Channel = F, DIMM = 1. SMI Handler (Channel # 00h)
Please help
Edward_Z_Intel
Apparently the DIMM in slot F1 is having error. Did you try it in a different slot to isolate the issue?
Please also check the http://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030026.htm Tested memory list. Notice the last "I" in the Part # for Kingston DIMMs - "I" indicates validated on Intel boards.
thx for answer, i change the ram in error slot for new one, and the server looks good.
The error on Intel® Active System Console 4.2 on slot F1 stay, clear of SEL and reinstall ASC was needed.
Now, all slot indicators green and 4-th reinstall to symulate error case run.
thx for advice.
JasonT_Intel
Typically a manual delete via IASC would remove the error. There are two options available when performing the action, delete from database or delete from BMC SEL memory would do the trick, no re-install of the IASC is necessary.
