5182 Discussions
Redundant PSU alert detection in S2600 servers
MQuev
Hello every one
I have several servers with S2600 motherboard. These servers have redundant PSU units.
I am using Centos 6 in these servers and I need to detect when one of the PSU units go faulty.
is this possible?
Martin
Hello Martin,
When a power supply goes faulty the system fans will go full speed so that will be the first signal for the issue. You can also detect a power supply by physically looking at it, it will show an amber LED. Another method is running the Intel(R) System information Retrieval Utility through the EFI shell and narrow the issue using that report.
MQuev
Thanks for the response.
The idea is to use sysinfo from linux command line to automatically detect the PSU going faulty. It is not practical to have someone looking at the LED status all the time.
is it possible?
The instructions to run the sysinfo command for Linux can be found on the release notes for the download link for the "Intel System Information Retrieval Utility (SysInfo)" for your board:
https://downloadcenter.intel.com/download/25437/Intel-System-Information-Retrieval-Utility-SysInfo- Download Intel System Information Retrieval Utility (SysInfo)
