- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
After BIOS/Firmware Update (24,1.05,11) of the S1200BTL motherboard in either SR1304 system, or Chenbro chassis,
the system stopps at the end of the boot.
The last message is: ME Firmware Version 2.0.8.15
We have this problem now with the 3rd board/system.
Konfiguration is with a E3-1230/1240 and 16 GB RAM.
We had configurations with RMM4 and SAS card, with and without Adaptec 5405/6405 controller, always the same problem.
Lien copié
3 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Very odd. Do you get any beep code, or system fault LEDs on the back of the board?
If you pull all the memory, do you get the three-beep code?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Remove the RMM4 module and try again. There is a known bug.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
All problems are now solved with the new BIOS (28) and Firmware.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
