5180 讨论
S1200BTLR: Active System Console "Data is being retrieved, Please retry"...
员工
2,919 次查看
I have a S1200BTLR motherboard with E3-1280 V2 and 16Gb ram.
Everything appears to be running fine with Server 2008 r2 sp1 64bit (enterprise edition).
However, I can't get the Intel Active System Console to work (I'm only trying to run it on the local machine).
When I logon it forever says "Data is being retrieved, Please retry".The documentation says it normal to get this message for a short while, but my installation never moves beyond this.
I've tried uninstalling and re-installing, several times, using version from the CD that came with motherboard (\software\windows\asc\asc_x64.exe), and latest download from Intel (IASC-5.0-Build15_Windows.zip).
Nothing seems to help.
I've updated all the bios and firmware:
Bios Version: S1200BT.86B.02.00.0037
Build date: 05/30/2012
BMC Firmware Version: 1.14.3503
SDR Version: SDR Package 1.14
ME Firmware Version: 2.2.0.36.
Can anyone help me with ideas to get this piece of software to work please?
Bryce Stenberg
IT Department
Harness Racing New Zealand Inc.
0 项奖励
6 回复数
Daniel_O_Intel
1,539 次查看
The only note I see in the readme is:
IASC needs several minutes to collect system data when ran for the first time, it may show
information "data is being retrieved, please retry". This is normal operation, re-login to IASC
to retry. Also check the hostname resolution on the server to include the domain name server
setting or hosts file configuration.
from
ActiveSystemConsole_Release_Notes
0 项奖励
员工
1,539 次查看
I had the same problem - I had first installed RAID Web Console, and that was the problem. After removal of both software and then I installed first ASC, everything was ok. After I installed RAID Web Console, everything was fine too.
0 项奖励
LVald
初学者
1,539 次查看
I have the same problem when connecting (locally or remotely) to ASC website. Every time I see the "Data is being retrieved, Please retry" message. Waiting doesn't helped. Connecting with IE9 or Firefox
System Information (S1200BTL):
RMM Status : Intel(R) RMM installed
Device (BMC) Available : Yes
BMC FW Build Time : May 25 2012 10:20:47
BMC FW Rev : 01.14
Boot FW Rev : 00.03
SDR Package Version : SDR Package 1.14
Mgmt Engine (ME) FW Rev : 02.02.00.049
Some logs (C:\Program Files (x86)\Intel\ASC\logs), after services (Appcore, IASCServiceManager) reboot.
error.log
2012-07-19 15:55:12: (log.c.172) server started
2012-07-19 15:55:12: (mod_fastcgi.c.1365) --- fastcgi spawning local
proc: C:/ASC/PHP/php-cgi.exe
port: 521
socket
min-procs: 1
max-procs: 1
2012-07-19 15:55:12: (mod_fastcgi.c.1390) --- fastcgi spawning
port: 521
socket
current: 0 / 1
2012-07-19 15:55:12: (mod_fastcgi.c.1087) the fastcgi-backend C:/ASC/PHP/php-cgi.exe failed to start:
2012-07-19 15:55:12: (mod_fastcgi.c.1091) child exited with status 0 C:/ASC/PHP/php-cgi.exe
2012-07-19 15:55:12: (mod_fastcgi.c.1094) If you're trying to run your app as a FastCGI backend, make sure you're using the FastCGI-enabled version.
If this is PHP on Gentoo, add 'fastcgi' to the USE flags.
2012-07-19 15:55:12: (mod_fastcgi.c.1398) [ERROR]: spawning fcgi failed.
2012-07-19 15:55:12: (server.c.932) Configuration of plugins failed. Going down.
2012-07-19 15:55:15: (log.c.172) server started
2012-07-19 15:55:15: (mod_fastcgi.c.1365) --- fastcgi spawning local
port: 521
socket
min-procs: 1
max-procs: 1
2012-07-19 15:55:15: (mod_fastcgi.c.1390) --- fastcgi spawning
port: 521
socket
current: 0 / 1
asclogfile.log
07/19/12 16:00:58 1504:3808 policyservice.exe exited abruptly
Any ideas?
Lukas
EDIT:
When installed new server 2008 r2 with ASC v5.5 (before Intel WRC2 installation) and connecting from windows XP with IE8 I have found some script warnings on the ASC site:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Timestamp: Thu, 26 Jul 2012 06:46:39 UTC
Message: Object required
Line: 856
Char: 4
Code: 0
URI: https://server:9393/asc/ajaxmsg.js https://server:9393/asc/ajaxmsg.js
Line: 210
Char: 13
Code: 0
URI: https://server:9393/asc/main.js https://server:9393/asc/main.js
Line: 856
Char: 4
Code: 0
...Line: 856 & Char: 4 repeating...
Line: 856
Char: 4
Code: 0
0 项奖励
LVald
初学者
1,539 次查看
0 项奖励
员工
1,539 次查看
The same problem with ASC and S1200BTL. Any ideas?
0 项奖励
RPore
初学者
1,539 次查看
I also have the same problem with a S1200BTLR. Any news or solutions for diesese problem?
0 项奖励
回复
