5177 Discussions
S1200BTLR Remote Web Management
ade_l5
I'm setting up remote managemnt web console. It is possible to force integrated web server to listen on a port *other than* default port 80?
Edward_Z_Intel
Unfortunately the answer is no. You can't change the default listening TCP port 80.
Edward_Z_Intel
ade_l5
Understood. Thanks.
It is bad idea to make remote management available on public interfaces - once internal server is compromised, the adversary has full access to console -> full access to the system. Always make remote management available only on trusted interfaces (for example internal network or VPN virtual interface).
