5181 Discussions
S1200BTS with F6 function for setting up RAID in SBS2003?
Does any one know? I use an USB floppy and connect onto internal USB port on S1200BLT, but SBS2003 just can't find it. I've tried other one USB floppy, same. But both USB floppy work fine with my laptop. I need to install SATA RAID driver for SBS2003, Help?
Edward_Z_Intel
SBS2003 is not officially supported on S1200BT. It's highly recommended to choose an OS from the http://www.intel.com/support/motherboards/server/sb/CS-032416.htm Tested operating system list.
To workaround your problem, try the following ways:
1. Use a USB floppy drive in Microsoft support list: http://support.microsoft.com/kb/916196 http://support.microsoft.com/kb/916196
2. Slipstream the driver into the installation CD: http://www.intel.com/support/motherboards/server/sb/CS-029550.htm http://www.intel.com/support/motherboards/server/sb/CS-029550.htm
