Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
S1200splr
Deeproads
Just bought this mother board did not come with a manual or io shield haven't work with this type of motherboard and i need help I'm hooking up the front case connector to the the server motherboard and eventide I turn it on it co es on fan spin then it stop I no I'm not hooking it up right need help
AlHill
Not a single comma or period in your post.  Makes it difficult to read and understand what you want.
Tech spec:
https://www.intel.com/content/dam/support/us/en/documents/server-products/S1200SP_TPS_AllSKU.PDF
Product spec:
https://ark.intel.com/content/www/us/en/ark/products/97950/intel-server-board-s1200splr.html
[If you find any Intel driver you might need, download and save it now.]
Deeproads
I ve hook up the server tower front connectors to the the server motherboard when turn on the server motherboard fans spin then stop the lights remain on I no I got it hook up wrong I found the manual but not really showing me the correct way
IntelSupport
Community Manager
Hello William,
Thank you for contacting Intel.
We would like to inform you that, the Intel® Server Board S1200SP Family you are using has reached its End of Interactive Support (EOIS). As a result, we will not be able to offer further support. We will proceed with closing the case.
Amina
Intel Server Support
Intel.com/vroc
