公告
5183 讨论
S2600-CP2 vmware ESXi 5.5 hangs on ACPI initialization -- Boot loop
JFox4
初学者
12,858 次查看
Hi all,
I recently upgraded the firmware of a working S2600CP2 server running VMWare ESXi 5.5 build 1474528 and VMWare now gets stuck on the initialization of ACPI. After about a minute or two of being stuck on the initialization of ACPI, the server reboots as if the reset button was pushed on the front of the server, basically resulting in a boot-loop.
System BIOS - 02.02.0002
ME Firmware - 02.01.07.328
BMC Firmware - 01.20 r5446
FRUSDR - 1.10
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23610&keyword=S2600Cp&lang=eng https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23610&keyword=S2600Cp&lang=eng
Here is a screenshot of the server info after the upgradepboot
Vmware hang screen-shot
0 项奖励
25 回复数
JFox4
初学者
1,622 次查看
Interesting idea Goutam.Nagella.
It never occurred to me that the ancient VGA monitor might not be compatible. The latest firmware that you linked was the firmware that I tried but it would not work. I will try the new version again this weekend with an LCD monitor to see what happens. Thanks for the suggestion and I will report my progress back to the group.
0 项奖励
JFox4
初学者
1,622 次查看
Well Goutam.Nagella, thanks for the suggestion, but changing the monitor didn't fix the issue. I also verified once again that the setting for MMIO above 4GB was disabled.
Thanks for the suggestion though. I would rather have the LCD monitor connected to the server than the CRT, so it wasn't a complete waste of time. :-)
If there is anyone else who has any ideas, I would love to hear them.
0 项奖励
David_A_Intel
主持人
1,622 次查看
I would suggest contacting http://www.intel.com/p/en_US/support/contactsupport Intel® Customer Support team to follow up this situation as I know you have been working on this situation for quite some time.
0 项奖励
JFox4
初学者
1,622 次查看
Hi @David_Intel,
I don't have a support agreement with them. That is why I posted in the community boards instead.
0 项奖励
David_A_Intel
主持人
1,622 次查看
You should be able to contact our support team without any contract or agreement. Our technical support is available for all Intel customers.
0 项奖励
回复
