S3420GPLC startproblem
员工
1,950 次查看
hi@all,
Board: S3420GPLC
CPU: i3-530
RAM: 4*KVR1333D3E9S/2GI
PSU: bgt p6-pro 430w (ATX12V 2.2)
After Boot up nothing happen. Just LEDs blinking an Beeps after press Power On Button as long as 5 sec.
LSB
XOXXOOOO
In the Userguide > 0xF2 O O O O X X O X Signal that the operating system has switched to virtual memory mode.
What could be the problem?
Is the PSU ATX12V ver to low?
Second: the PSU runs if I press the PSU switch on the back. Thats not normal.
As I read some things I should check:
- Board BIOS ver (higher 40?)
If it is to low where can I check it on the Board without start.
regards
0 项奖励
2 回复数
Daniel_O_Intel
1,025 次查看
The good news is, the BIOS version on this board will never prevent booting. Even an old BIOS will still get you video, and messages.
Each 12V rail needs a maximum of 16A - what does your power supply provide?
0 项奖励
Edward_Z_Intel
1,025 次查看
See if it's related to this one: http://www.intel.com/support/motherboards/server/sb/CS-031225.htm TA-943: Board may not boot with certain processors or http://www.intel.com/support/motherboards/server/sb/CS-031713.htm BIOS 42 or later required to boot certain processors
0 项奖励
回复
