S5000PSL raid firmware
I am re-purposing some servers with S5000PSL boards in them. I updated the BIOS, BMC and FRU. I noticed there were two choices of firmware to update the raid;
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19804&lang=eng&OSVersion=OS%20Independent&DownloadType=# help http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19804&lang=eng&OSVersion=OS%20Independent&DownloadType=# help
or
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19008&lang=eng&OSVersion=OS%20Independent&DownloadType= http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19008&lang=eng&OSVersion=OS%20Independent&DownloadType=
These are in non-Intel chassis, no backplanes just two SAS drives that I will mirror.
I would like to have the latest RAID firware on these when I redeploy them.
Any input on which I should be using would be greatly appreciated.
Edward_Z_Intel
Hope this small tool can help you to locate the correct download:
http://www.intel.com/support/motherboards/server/sb/CS-030283.htm http://www.intel.com/support/motherboards/server/sb/CS-030283.htm
If you're using onboard SATA RAID, the FW is included in the BIOS alreadly.
DSilv11
Valued Contributor III
Sure hope he's not using the on-board SATA raid as he would likly have lots a problems talking to his 2 SAS HDD.
Edward_Z_Intel
Oh sorry for missing that part... Thanks for pointing that out Doc.
