S5000VSA Disk Limit
ZZain
Dear Intel Support,
I understand S5000VSA is old mobo and discontinue of any support, but i would like to know what the maximum of disk space are able to run with this mobo, i did try with 4TB and no problem at all, but now i plan to use 6TB, is it possible ?
TQ
Hello halimzhz,
Here Henry from Intel Support, related to your question about the max HDD storage for the S5000VSA.
First, let me provide you with some information on the system, according to the system model, is under EOIS, you can verify this on the following pages:
https://ark.intel.com/products/46535/Intel-Server-Board-S5000VSASATAR https://ark.intel.com/products/46535/Intel-Server-Board-S5000VSASATAR
https://www.intel.com/content/www/us/en/support/articles/000020015/server-products.html https://www.intel.com/content/www/us/en/support/articles/000020015/server-products.html
I am going to try and find as much information to help you with your question.
I also invite you to move the thread to the Discontinued section of the Community for the current interaction or future ones.
Checking the TPS - https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s5000vsa/sb/d36978010_s5000vsa_tps_r1_9.pdf https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s5000vsa/sb/d36978010_s5000vsa_tps_r1_9.pdf
It used HDD up to 300GB at that moment. But I've read on other posts that they have used 1 TB HDD's.
Here the best option will be to get at least one HDD of 1 TB or even 2 TB and test it.
I am going to verify if we have any documents that can support the usage of the size HDD.
If there is anything else we can help please feel free to ask.
Henry A.
ZZain
Dear Henry,
TQ so much, What i did tested before, i can run with 4TB disk but i need to make sure is it possible if i run with 6TB before i buy the disk
TQ
Hello halimzhz,
I really understand and I am still looking for a similar system. But I am afraid is not available for testing. And at this moment there is nothing we can do at this moment.
I wish I had some other news, the only option is to see if some has a the HDD that you need and allow you to use it for testing.
Thank you for your time and patience.
Henry A.
Hello halimzhz,
I just wanted to follow up if there is anything else I can help you. I am fraid the I wasn't able to find a 6 TB HDD for testing.
Henry A.
Hello halimzhz,
At this moment we will proceed on closing this threat as we haven't received any updates on the case.
If you require any additional support, please create a new threat and refer back to this one.
Henry A.
