5173 Discussions
SMBUS connection from MCIO connector to BMC in Eagle Stream Archer City
GTLee
I'm involving BMC S/W development with OpenBMC on the Eagle Stream Archer City.
I'd like to develop an application using NVMe-MI and MCTP protocol between SSD and BMC.
As I figure out from the schematic, SMBUS from the front panel is connected to secondary FPGA.
SMB_PEHPCPU0_NVME1_LVC3_SCL --> PCA9544_A --> SMB_PEHPCPU0_LVC3_SCL --> 10M25DA (Secondary FPGA)
And it is hard to follow up how it can be connected to the BMC.
Could you provide explanation or guide for this connection?
If you can S/W guide (like 'how to use mtcpd with pcie binding') either, it would be very appreciated.
GT Lee.
Allan_A_Intel
Hello, GTLee,
Thank you for your confirmation. Since you are working with an Intel® Software Development Platform, I recommend you getting through the dedicated support center, which provides privileged access as well as creates access for ticketing for the Online Service Center: https://www.intel.com/content/www/us/en/design/software-development-platforms/sdp-design-center.html
I hope you can find in there the documentation and the instructions you need.
Allan
Allan_A_Intel
Hello, GTLee,
Thank you for reaching Intel Communities. I will gladly help you.
Perhaps I can find the type of information that you need. Please let me know if you are developing with an Intel server system, and also let me know what is its model number.
Allan
GTLee
Hello, Allan,
Maybe it is the model name you requested.
Intel® Eagle Stream 2S Pre-Alpha SDP S2EG1SI51A MM# 99A9HK.
If it isn't, please let me know how I can find it from the board.
GT Lee.
GTLee
Hello, Allan,
Thank you for your answer.
I don't have a model number because my job is developing an application on the OpenBMC using Intel CRB Sapphire Rapids.
And actually the application that will be implemented, won't be dependent with specific server, but is dependent with Intel architecture for CPU and BMC and drives.
GT Lee.
Allan_A_Intel
Hello, GTLee,
Allan
