SR1640TH supported cpu
OSEN
I have a i3 560 (SLBY2) cpu but at
http://www.intel.com/support/motherboards/server/sr1640th/sb/CS-031628.htm http://www.intel.com/support/motherboards/server/sr1640th/sb/CS-031628.htm
it states this platform only supports
I3-540http://ark.intel.com/Product.aspx?spec=SLBMQ SLBMQ3.06 GHz4MB73 W2
I3-530
http://ark.intel.com/Product.aspx?spec=SLBLR SLBLR2.93 GHz4MB73 W2
What is the difference between I3-540 and I3-560 so this cpu is not supported on SR1640TH
Regards.
Daniel_O_Intel
If it is not on the list of supported processors, I would not put it in the system.
You can compare the details of the two processors at
http://mark.intel.com/Product.aspx?spec=SLBMQ http://mark.intel.com/Product.aspx?spec=SLBMQ and
http://mark.intel.com/Product.aspx?spec=SLBY2 http://mark.intel.com/Product.aspx?spec=SLBY2
