SS4000-E Folder Access Problem.
i have a ss4000-e model storage. There are 1 piece on the disc storage unit 1 tb. This disk is full. I put on the second disc storage unit and saw it. I put the third disc, but he stopped to access the folder.
ss4000-e Firmware(now): 1.3b524
before: 1.0
1.hdd: 1 tb (very important in the data.)
2.hdd: 1 tb
3.hdd: 1 tb
Raid Structure: Linear
I can see the shared folders, but I can not enter into.
screen shots below;
http://www.piramit.com.tr/documents/ss4000/1.jpg http://www.piramit.com.tr/documents/ss4000/1.jpg
http://www.piramit.com.tr/documents/ss4000/2.jpg http://www.piramit.com.tr/documents/ss4000/2.jpg
http://www.piramit.com.tr/documents/ss4000/3.jpg http://www.piramit.com.tr/documents/ss4000/3.jpg
http://www.piramit.com.tr/documents/ss4000/4.jpg http://www.piramit.com.tr/documents/ss4000/4.jpg
Please help me fix this issue?
i can connect to ss4000-e via ssh, but i can't access my data.
fdisk -l command's out from ss4000-e ssh console;
# fdisk -l
Disk /dev/sda: 16 heads, 63 sectors, 1938021 cylinders
Units = cylinders of 1008 * 512 bytes
Device Boot Start End Blocks Id System
/dev/sda1 1 261 131543+ 83 Linux
/dev/sda2 262 522 131544 82 Linux swap
/dev/sda3 523 1938022 976499496+ 89 Unknown
Disk /dev/sdb: 16 heads, 63 sectors, 1938021 cylinders
/dev/sdb1 1 261 131543+ 83 Linux
/dev/sdb2 262 522 131544 82 Linux swap
/dev/sdb3 523 1938022 976499496+ 89 Unknown
Disk /dev/sdc: 16 heads, 63 sectors, 1938021 cylinders
/dev/sdc1 * 1 1926079 970743658+ 83 Linux
Partition 1 does not end on cylinder boundary:
phys=(1023, 254, 63) should be (1023, 15, 63)
/dev/sdc2 1926079 1938016 6016342+ 5 Extended
Partition 2 does not end on cylinder boundary:
/dev/sdc5 1926079 1938016 6016311 82 Linux swap
My data place on /dev/sda3 partition. This partition unknown case, How can I repair /dev/sda3
Daniel_O_Intel
Unfortunately your pictures are not displaying.
When you added the new hard drives, did you do a Scan as mentioned in the User Guide at http://www.intel.com/support/motherboards/server/ss4000-e/sb/CS-022215.htm http://www.intel.com/support/motherboards/server/ss4000-e/sb/CS-022215.htm ?
I have read most of the guides on this subject, but unfortunately I could not find a solution.
The most recent case;
Partition sda3 is my files, now seems to be unknown. System which has corrupted xfs partition. Necessary to repair or rescue the files in this section. How I can make it?
Daniel_O_Intel
If you didn't follow the steps on insertion, I would remove the third HD immediately, and see if you can get your original data back.
I bought a data recovery software. I get data on the HDD with recovery software.
I hate the SS4000...
I have meet the same problem.
please help me
what software you used for recover your data ?
same problem (and no more shared folder "public" listed ...)
Any help ???
You can try to use Yesterdata Data Recovery trial version.
download site: http://www.yesterdata.net/ http://www.yesterdata.net/
the software has 6 data recovery modules, i think the HDD Partitions Lost suits your need. Just make a free scan.
