5173 ディスカッション
SS4000-E, rebuild and shared folder "not ready"
従業員
3,316件の閲覧回数
Hi all,
i've a trobule with a Lacie Ethernet Disk Raid (a Lacie branded Intel SS4000-E) with a RAID 5 w/o spare disk.
The disk n. 2 failed and I was unable to continue to work with NAS (partition was mounted with NFS on a linux server).
So I bought a new disk (the disk n. 2 ...) and i'm still rebuilding RAID.
In the 1st page i see:
Whill shared folder came ready when RAID finished rebuild ?
Tnx in advance for help.
BoB
0 件の賞賛
6 返答(返信)
Daniel_O_Intel
従業員
2,226件の閲覧回数
On a RAID 5, the data should be available regardless of the status of the replacement drive.
Does Lacie's version have any special restriction, that you know of?
従業員
2,226件の閲覧回数
Hi Dan,
raid5 was rebuilt. The strange is that NAS can't mount /public.
I can access to NAS in ssh.
# mdadm --detail --scanARRAY /dev/md1 level=raid5 num-devices=4 UUID=07c2125e:d6e1b735:8c50bf4f:ef9fce2c devices=/dev/sda3,/dev/sdb3,/dev/sdc3,/dev/sdd3ARRAY /dev/md0 level=raid1 num-devices=4 UUID=4806857a:89707292:e7c4e35a:c47018fd devices=/dev/sda1,/dev/sdb1,/dev/sdc1,/dev/sdd1
# mdadm --detail --scan /dev/md1
/dev/md1:
Version : 00.90.01
Creation Time : Thu May 15 13:51:30 2008
Raid Level : raid5
Array Size : 2196539520 (2094.78 GiB 2249.26 GB)
Device Size : 732179840 (698.26 GiB 749.75 GB)
Raid Devices : 4
Total Devices : 4
Preferred Minor : 1
Persistence : Superblock is persistent
Update Time : Sat Apr 7 07:40:51 2012
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
UUID : 07c2125e:d6e1b735:8c50bf4f:ef9fce2c
Events : 0.104795538
Number Major Minor RaidDevice State
0 8 3 0 active sync /dev/sda3
1 8 19 1 active sync /dev/sdb3
2 8 35 2 active sync /dev/sdc3
3 8 51 3 active sync /dev/sdd3
# dmesg
md: md1 stopped.
md: bind
md: bind
md: bind
md: bind
raid5: device sda3 operational as raid disk 0
raid5: device sdd3 operational as raid disk 3
raid5: device sdc3 operational as raid disk 2
raid5: device sdb3 operational as raid disk 1
raid5: allocated 4201kB for md1
raid5: raid level 5 set md1 active with 4 out of 4 devices, algorithm 2
RAID5 conf printout:
--- rd:4 wd:4 fd:0
disk 0, o:1, dev:sda3
disk 1, o:1, dev:sdb3
disk 2, o:1, dev:sdc3
disk 3, o:1, dev:sdd3
... The RAID5 exists and is allocated as MD1 # fdisk -l /dev/md1You must set cylinders.You can do this from the extra functions menu. Disk /dev/md1: 2 heads, 4 sectors, 0 cylindersUnits = cylinders of 8 * 512 bytes Device Boot Start End Blocks Id System/dev/md1p1 1 2009 8032 77 UnknownPartition 1 has different physical/logical endings: phys=(0, 254, 63) logical=(2008, 0, 1)Partition 1 does not end on cylinder boundary: phys=(0, 254, 63) should be (0, 1, 4)/dev/md1p2 2009 536870910 2147475607+ 88 UnknownPartition 2 has different physical/logical beginnings (non-Linux?): phys=(1, 0, 1) logical=(2008, 0, 2)Partition 2 has different physical/logical endings: phys=(1023, 254, 63) logical=(536870909, 1, 4)Partition 2 does not end on cylinder boundary: phys=(1023, 254, 63) should be (1023, 1, 4) But i can't mount # mount -t xfs /dev/md1 /nas/NASDisk-00003/public/mount: Mounting /dev/md1 on /nas/NASDisk-00003/public failed: Invalid argument Any ideas ???
従業員
2,226件の閲覧回数
Does /nas/NASDisk-00003/public/ exist?
John
従業員
2,226件の閲覧回数
No, i have hand made make with mkdir.
The strange is:
XFS mounting filesystem vbdi2Ending clean XFS mount for filesystem: vbdi2XFS mounting filesystem vbdi3XFS: Log inconsistent (didn't find previous header)XFS: failed to find log headXFS: log mount/recovery failed: error 5XFS: log mount failedXFS mounting filesystem vbdi2Ending clean XFS mount for filesystem: vbdi2XFS mounting filesystem vbdi3XFS: Log inconsistent (didn't find previous header)XFS: failed to find log headXFS: log mount/recovery failed: error 5XFS: log mount failedXFS mounting filesystem vbdi3XFS: Log inconsistent (didn't find previous header)XFS: failed to find log headXFS: log mount/recovery failed: error 5XFS: log mount failed
Then /dev/md1 (vbdi2) has xfs filesystem troubles ...
Edward_Z_Intel
従業員
2,226件の閲覧回数
Try this one:
mount -t xfs /dev/vbdi3 /nas/NASDisk-00003
If it's not working you may try to run xfs_check on /dev/vbdi3.
従業員
2,226件の閲覧回数
I love u man ! You saved me !!!!!!!
I tried:
# xfs_repair /dev/vbdi3
and reboot.
SS4000-E mounted regulary and all data was there
返信
