5168 Discussions
Sobre Xeon® E5-2690 la velocidad y los MIPS que ejecuta?
MJime8
Alguien que me pueda apoyar con la información de los MIPS del Xeon E5-2690
Hello Marck.jt7
Thank you for reaching the Intel Communities.
I understand you would like to check if this processor supports an instruction set. For sure we can check on this to find out if it is supported.
There are different models of that processors, could you please confirm which is the version you have?
PS: Support is provided in English only, sorry for any inconvenience
Esteban C
Hello Marck.jt7,
This is to do a follow up to your post and find out if you were able to check my answer.
Esteban C
