5181 Discussions
SuSE Linux Enterprise 11 SP1 under Modular Server MFSYS25V2: (Dual-) SCM Problem / MultiPath
We are trying to install SLES 11 SP1 x64 on a MFS5520VIBR Compute-Modul and are facing a
critical problem regarding MultiPath.
uname -a
Linux LXTEST 2.6.32.12-0.7-default # 1 SMP 2010-05-20 11:14:20 +0200 x86_64 x86_64 x86_64 GNU/Linux
Installation Medium:
SLES-11-SP1-DVD-x86_64-GM-DVD1
Our Installation Procedure:
- Remove SCM # 2
- Create Virtual Drive
- Basic Installation of SLES 11 SP1 (apply almost all default settings)
- Install rpm package: (from Package SLES11SP1_MPIO_Setup20110712)
rpm -ivh --force scsi_dh_alua_sles11sp1-2-1.x86_64.rpm
- Copy MultiPath-Config (without editing) (from Package SLES11SP1_MPIO_Setup20110712)
cp multipath.conf /etc/multipath.conf
- Activate MultiPathD
multipathd on
- Ensure that MultiPathD is running
multipathd on
===> Output: multipathd on
- Plug-In the SCM # 2
- Reboot Compute-Modul
_____________________________________________________________
Output of multipath -ll:
Output of multipath -v4:
Feb 29 10:54:40 | Discover device /sys/block/sdb
Feb 29 10:54:40 | sdb: not found in pathvec
Feb 29 10:54:40 | sdb: mask = 0x1f
Feb 29 10:54:40 | sdb: dev_t = 8:16
Feb 29 10:54:40 | sdb: size = 83886080
Feb 29 10:54:40 | sdb: subsystem = scsi
Feb 29 10:54:40 | sdb: vendor = Intel
Feb 29 10:54:40 | sdb: product = Multi-Flex
Feb 29 10:54:40 | sdb: rev = 0308
Feb 29 10:54:40 | sdb: h:b:t:l = 0:0:1:0
Feb 29 10:54:40 | sdb: serial = 4C20202000000000000000008714B4EE666632D3
Feb 29 10:54:40 | sdb: get_state
Feb 29 10:54:40 | loading /lib64/multipath/libchecktur.so checker
Feb 29 10:54:40 | sdb: path checker = tur (controller setting)
Feb 29 10:54:40 | sdb: state = running
Feb 29 10:54:40 | sdb: state = up
Feb 29 10:54:40 | sdb: getuid = /lib/udev/scsi_id -g -u /dev/%n (controller setting)
Feb 29 10:54:40 | sdb: uid = 222910001555ba713 (callout)
Feb 29 10:54:40 | sdb: prio = alua (controller setting)
Feb 29 10:54:40 | reported target port group is 1
Feb 29 10:54:40 | aas = 80 [active/optimized] [preferred]
Feb 29 10:54:40 | sdb: alua prio = 150
Feb 29 10:54:40 | Discover device /sys/block/sda
Feb 29 10:54:40 | sda: not found in pathvec
Feb 29 10:54:40 | sda: mask = 0x1f
Feb 29 10:54:40 | sda: dev_t = 8:0
Feb 29 10:54:40 | sda: size = 83886080
Feb 29 10:54:40 | sda: subsystem = scsi
Feb 29 10:54:40 | sda: vendor = Intel
Feb 29 10:54:40 | sda: product = Multi-Flex
Feb 29 10:54:40 | sda: rev = 0308
Feb 29 10:54:40 | sda: h:b:t:l = 0:0:0:0
Feb 29 10:54:40 | sda: serial = 4C20202000000000000000008714B4EE666632D3
Feb 29 10:54:40 | sda: get_state
Feb 29 10:54:40 | sda: path checker = tur (controller setting)
Feb 29 10:54:40 | sda: state = running
Feb 29 10:54:40 | sda: state = up
Feb 29 10:54:40 | sda: getuid = /lib/udev/scsi_id -g -u /dev/%n (controller setting)
Feb 29 10:54:40 | sda: uid = 222910001555ba713 (callout)
Feb 29 10:54:40 | sda: prio = alua (controller setting)
Feb 29 10:54:40 | reported target port group is 0
Feb 29 10:54:40 | aas = 02 [standby]
Feb 29 10:54:40 | sda: alua prio = 1
Feb 29 10:54:40 | Discover device /sys/block/sdc
Feb 29 10:54:40 | sdc: not found in pathvec
Feb 29 10:54:40 | sdc: mask = 0x1f
Feb 29 10:54:40 | sdc: dev_t = 8:32
Feb 29 10:54:40 | sdc: size = 0
Feb 29 10:54:40 | sdc: subsystem = scsi
Feb 29 10:54:40 | sdc: vendor = Virtual
Feb 29 10:54:40 | sdc: product = Floppy
Feb 29 10:54:40 | sdc: rev = 1.00
Feb 29 10:54:40 | sdc: h:b:t:l = 1:0:0:1
Feb 29 10:54:40 | Couldn't open node for sdc: No medium found
Feb 29 10:54:40 | Discover device /sys/block/sr0
Feb 29 10:54:40 | sr0: device node name blacklisted
Feb 29 10:54:40 | Discover device /sys/block/loop0
Feb 29 10:54:40 | loop0: device node name blacklisted
Feb 29 10:54:40 | Discover device /sys/block/loop1
Feb 29 10:54:40 | loop1: device node name blacklisted
Feb 29 10:54:40 | Discover device /sys/block/loop2
Feb 29 10:54:40 | loop2: device node name blacklisted
Feb 29 10:54:40 | Discover device /sys/block/loop3
Feb 29 10:54:40 | loo...
Daniel_O_Intel
It looks like you've done all the steps from http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18634 http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18634
I haven't tried SLES 11 SP1 - do you have a non-service-packed distro to test with? There might be something in the service pack that changed.
Try set your path grouping policy to group_by_serial in multipath.conf (reboot for changes to kick in)
path_grouping_policy "group_by_serial"
