5180 Discussions
Update a MFS5520VI with MFSYS25V2 chasis failing
frenchface
Hey I have an MFSYS25V2. The chassis is version 11.6.100.20120307.34736. I have 3 up to date MFS5520VI that are working perfectly which have the following versions:
BMC Firmware: 1.27.1
BMC Boot: 0.28
BIOS S5500.86B.01.20.0055
I bought 3 additional MFS5520VI which are failing to update the firmware and I will eventually get the unfit component.
The 3 new (used) MFS5520VI have BIOS: S5500.86B.01.10.0043
I've tried the force BMC Update and booted to EFI Shell and tried to manual update the bios to version S5500.86B.01.00.0069.032620181413 however I get:
unable to initialize smbios library
I"m guessing I need to update two different versions before updating to the latest. Any thoughts?
JoseH_Intel
Hello frenchface,
Thank you for joining the community
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request. Thank you for understanding.
You can find the available support information in the this site: https://www.intel.com/content/www/us/en/support/products/48002/server-products/legacy-server-products/intel-compute-module-mfs5000vi-family/intel-compute-module-mfs5520vir.html
Jose A.
Accessitltd
The error that you get means that does not recognize the library of the version you re tring to upgrade.
Probably the used ones have an older or different bios. Try to reset the new (used) blades.
Also look here if you can help please
https://community.intel.com/t5/Server-Products/INTEL-MODULAR-SERVER-FLEXPOWER/m-p/1312042/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEtUNFRBNEpNNTA5TzBFfDEzMTIwNDJ8U1VCU0NSSVBUSU9OU3xoSw#M21142
