I'm using Intel Server Board S5500BC, because of having trouble with my old SATA HDD 500GB, maybe too many bad sectors, so I purchased brand new SAS HDD 2TB.
I'm facing another problem, since old HDD is SATA type, then I use SATA to SAS converter cable, but when I try to install Windows Server, none HDD is detected.
Is it possible to use SAS HDD 2TB on Intel Server Board S5500BC?
Can this problem be solved using driver for SAS HDD?
Kevin
链接已复制
Hi @KevinK ,
It shouldn't compatible to install SAS HDD 2TB to Intel Server Board S5500BC's sata.
You may refer to this specification and datasheet from this link:
Link:https://www.intel.com/content/www/us/en/products/sku/36601/intel-server-board-s5500bc/specifications.html
Please let me know if I can be of any assistance. Thank you.
BY_Intel
Intel Customer Support
Hi @KevinK ,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know.
In case we do not hear from you, I will make a follow up on May 24th 2023 . Thank you.
BY_Intel
Hi @KevinK ,
Thank you for your patience.
I don't think using PCIX to SAS Controller Card will make it work, since I believe your server board may not have SAS module enable.
You may refer to the list of compatible controller from Compatible Products tab at the given url:
BY_Intel
Hi Intel CS,
Thanks for your reply and the link that refer to the list of compatible controller cards.
Regarding from the list given above, mostly had been discontinued, so I searched other brands. After trying several products, finally I got the best matching RAID controller card from Dell, PERC H310, and it works very well.
Thank you.
Kevin
Hi @KevinK ,
In case we do not hear from you, I will make a follow up on May 31st 2023 . Thank you.
BY_Intel
Hi @KevinK ,
Please be informed that we will now close this request since you have found the solution. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
BY_Intel
