5190 Discussions
Which PSU for Intel S5000PSLROMBR server board
Hi, i want to build a very silenced home server.
I want to know if the Enermax MODU82+ EMD625AWT PSU work with the mainboard ?
Which standard is the mainboard ?
ATX / EATX / other ?
Thanks for your advice.
Edward_Z_Intel
The standard is called SSI (Server System Infrastructure). See http://www.intel.com/support/motherboards/server/s5000psl/sb/CS-022619.htm S5000PSL and S5000XSL technical product specification for power requirements. I'd suggest you choose a http://www.intel.com/support/motherboards/server/sb/CS-022653.htm Tested Intel® Chassis or http://www.intel.com/support/motherboards/server/sb/CS-022654.htm Reference chassis.
Hmm the problem is that i want a SILENT server because my girlfriend dont like the noise of my other computer.
I want to put the mainboard in a ANTEC P 193 case.
And i want of course an psu with a 120mm silent fan.
Did you konw if i can use another psu than the INTEL one ?
Thanks in advance.
Jon
JPete15
Hi samzor,
I've been running my S5000PSL based server with a Corsair TX650W V2 PSU for quite some time now.
Just remember that the PSU you get is capable of delivering at least 3A on the 5V standby rail; 2.5A is NOT enough - i learned that the hard way.
- Dfir
