5173 Discussions
X56xx compatibility with SR2600URLX
A client has an Intel server SR2600URLX, containing a S5520UR motherboard.
We want to upgrade the processors from E5506 to X5670/80/90.
I am receiving conflicting information from official Intel suppliers here (they do not know if these processors will work on that platform).
On the server system support page - compatibility with processors, X56xx are not listed:
http://ark.intel.com/products/48666/Intel-Server-System-SR2600URLX ARK | Intel&# 174; Server System SR2600URLX - compatible products/processors.
However, on X5670 and X5680 support pages at least, they are compatible with S5520UR motherboard, but not with the whole server?
http://ark.intel.com/products/47920/Intel-Xeon-Processor-X5670-12M-Cache-2_93-GHz-6_40-GTs-Intel-QPI?q=x5670 http://ark.intel.com/products/47920/Intel-Xeon-Processor-X5670-12M-Cache-2_93-GHz-6_40-GTs-Intel-QPI?q=x5670
http://ark.intel.com/products/47916/Intel-Xeon-Processor-X5680-12M-Cache-3_33-GHz-6_40-GTs-Intel-QPI?q=x5680 http://ark.intel.com/products/47916/Intel-Xeon-Processor-X5680-12M-Cache-3_33-GHz-6_40-GTs-Intel-QPI?q=x5680
Also, this document:
http://www.intel.com/support/motherboards/server/sb/CS-030213.htm http://www.intel.com/support/motherboards/server/sb/CS-030213.htm
leads me to believe all 3 processors X5670, X5680, X5690 should work on this system, with enhanced cooling solution BXSTS100C ?
Can I get an official answer for this please? If the processors don't fit, what would be the top two available processors for this system?
Thank you very much!
Tudor
Details (from dmidecode):
System Information
Manufacturer: Intel Corporation
Product Name: S5520UR
UUID: 74DCDCF6-30BC-11DE-B020-001517B11420
Base Board Information
Version: E22554-604
Serial Number: BZUB91703263
BIOS Information
Vendor: Intel Corp.
Version: S5500.86B.01.00.0061.030920121535
Release Date: 03/09/2012
From RMM3:
Device (BMC) Available :Yes
BMC FW Build Time :Mar 11 2012 21:13:20
BMC FW Rev :00.59
Boot FW Rev :00.16
SDR Package Version :SDR Package 0.26
Primary HSC FW Rev :02.09
Secondary HSC FW Rev :(not present)
Mgmt Engine (ME) FW Rev :01.12.007.0
Local Control Panel (LCP) FW Rev :(not present)
Edward_Z_Intel
Yes it's supported. Thermal limitation is documented in note 3 of http://www.intel.com/support/motherboards/server/sb/CS-030213.htm Tested processor list, which doesn't apply to you:
3. Supported under the Intel® Server Board S5520UR and associated SKUs (SR1600UR, SR1625UR, SR2600UR and SR2625UR). When using this processor with a 1U system (SR16xxUR), use only Single or Dual Rank DIMMs due to thermal limitation.
Use the passive heatsink that comes with your system. No additional thermal solution is required.
Edward_Z_Intel
