5181 Discussions
Xeon w5 does not enabled DSA SVM feature
YongInLee
Hello
I cannot enable SVM feature of DSA.
[ 5.863737] idxd 0000:e7:01.0: enabling device (0144 -> 0146)
[ 5.863765] idxd 0000:e7:01.0: Unable to turn on user SVA feature.
[ 5.884903] idxd 0000:e7:01.0: Intel(R) Accelerator Device (v100)
This kernel options are enabled for SVM.
# cat config-6.7.9-svm1 | grep INTEL_IOMMU
CONFIG_INTEL_IOMMU=y
CONFIG_INTEL_IOMMU_SVM=y
CONFIG_INTEL_IOMMU_DEFAULT_ON=y
CONFIG_INTEL_IOMMU_FLOPPY_WA=y
CONFIG_INTEL_IOMMU_SCALABLE_MODE_DEFAULT_ON=y
CONFIG_INTEL_IOMMU_PERF_EVENTS=y
# cat config-6.7.9-svm1 | grep IDXD
CONFIG_INTEL_IDXD_BUS=m
CONFIG_INTEL_IDXD=m
# CONFIG_INTEL_IDXD_COMPAT is not set
CONFIG_INTEL_IDXD_SVM=y
CONFIG_INTEL_IDXD_PERFMON=y
I used 6.7.9 mainline kernel on Ubuntu 22.04.3.
My Xeon system is assembled Xeon W5-3435X and Supermicro X13SWA-TF board.
# lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 46 bits physical, 57 bits virtual
Byte Order: Little Endian
CPU(s): 32
On-line CPU(s) list: 0-31
Vendor ID: GenuineIntel
Model name: Intel(R) Xeon(R) w5-3435X
CPU family: 6
Model: 143
Thread(s) per core: 2
Core(s) per socket: 16
Socket(s): 1
Stepping: 8
CPU max MHz: 4700.0000
CPU min MHz: 800.0000
BogoMIPS: 6200.00
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx
pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pc
lmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid dca sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline
_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb cat_l3 cat_l2 cdp_l3 intel_ppin cdp_l2 ssbd mba ibrs ibp
b stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a avx512
f avx512dq rdseed adx smap avx512ifma clflushopt clwb intel_pt avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves cqm
_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local split_lock_detect avx_vnni avx512_bf16 wbnoinvd dtherm ida arat pln pts hwp hwp_act_
window hwp_epp hwp_pkg_req vnmi avx512vbmi umip pku ospke waitpkg avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg tme a
vx512_vpopcntdq la57 rdpid bus_lock_detect cldemote movdiri movdir64b enqcmd fsrm md_clear serialize tsxldtrk pconfig arch_lbr ibt
amx_bf16 avx512_fp16 amx_tile amx_int8 flush_l1d arch_capabilities
Virtualization features:
Virtualization: VT-x
Caches (sum of all):
L1d: 768 KiB (16 instances)
L1i: 512 KiB (16 instances)
L2: 32 MiB (16 instances)
L3: 45 MiB (1 instance)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-31
Vulnerabilities:
Gather data sampling: Not affected
Itlb multihit: Not affected
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Not affected
Retbleed: Not affected
Spec rstack overflow: Not affected
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Spectre v2: Mitigation; Enhanced / Automatic IBRS, IBPB conditional, RSB filling, PBRSB-eIBRS SW sequence
Srbds: Not affected
Tsx async abort: Not affected
# dmidecode -t 2
# dmidecode 3.3
Getting SMBIOS data from sysfs.
SMBIOS 3.5.0 present.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: Supermicro
Product Name: X13SWA-TF
Version: 1.01
Serial Number: WM235S004563
Asset Tag: Base Board Asset Tag
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Part Component
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
If you have guide for this system, help me please.
Poojitha
Hello YongInLee
Thank you for posting in Intel Community.
Please allow us some time to review the details and we will get back with an update shortly
Poojitha
Dineshbabu
Hello YongInLee
To enable the DSA SVM feature, please get in touch with Super Micro. Please refer to the to the below link for your rference.
https://www.supermicro.com/en/accelerators/intel/built-in-on-demand
which shows how to enable Intel Data Streaming Accelerator on their technical specifications.
Please find the below link for the generak guide for DSA:
https://www.colfax-intl.com/downloads/Public-Accelerators-Deep-Dive-Presentation-Intel-DSA.pdf
Dinesh
Poojitha
Hello YongInLee,
Greetings from Intel
Poojitha
Poojitha
Hello YongInLee,
Poojitha
