It looks like I'm going to be getting access to a Xeon CPU MAX server to experiment with (mostly to evaluate enabling applications for HBM). Given it's fairly new and the HBM is not a common feature I started wondering what, if any, things I should be looking for in terms of software (primarily OS) install. The server vendor just has the CPU MAX listed as one of many CPU options and say "RedHat 8.6/9.0". Intel has https://www.intel.com/content/www/us/en/content-details/787743/intel-xeon-cpu-max-series-configuration-and-tuning-guide.html which recommends the "latest stable kernel (currently 5.15)" but further sections list a few features that require newer (5.16, 6.1, etc...) kernels.
My sysadmins are going to want to put RedHat 9 on it, and as best as I can tell that means a 5.14 kernel. About the only thing I was able to find regarding RedHat supporting "CPU MAX" processors was: https://catalog.redhat.com/hardware/components/detail/234257
So, does anyone have experience with such a system and some suggestions on how to set it up?
Hello CFR,
Greetings for the day!
At the moment, we are actively working towards finding an appropriate resolution for your issue, and we will provide you with an update as soon as we can. We kindly request your cooperation during this time.
Vijay N
Thanks. I'm not really sure this is specifically a question for Intel, but as this is supposed to be an "community" forum I'm hoping may some other user's might have some related experience. I'll take all the help I can get.
Hello CFR,
Please note that HBM allows kernel 5.16 access without additional DAX commands, enabling visibility of HBM nodes post-boot. However, this action reserves a small portion of HBM memory from each NUMA node for metadata storage.
For more details please find the attached link:
https://lenovopress.lenovo.com/lp1810-enabling-high-bandwith-memory-in-flat-memory-mode-on-linux
For optimal utilization of HBM in Red Hat Enterprise Linux, considering the specific features of CPU MAX, We recommend reaching out to the Red Hat community or support.
vijay.
Hello CFR,
Hope you're doing well!
We are following up to check if you have any questions from the previous communication. If you do, please feel free to let us know.
Vijay N.
Hello CFR,
We have not received a reply from you , and as such, we will be closing your case.
If you want to continue support, please reply to this post and we will reopen your case or create a new one so that we can continue to support you.
Vijay N.
Sorry I was hoping someone would be able to provide some additional guidance.
You can close this is request.
For future searchers...
I haven't found any authoritative documents on OS support (especially RedHat 9) but I did stumble across the following which looks useful...
