5181 討論
memory thrm related warnings/errors on vmware.
RSmir
初學者
9,321 檢視
Добрый день !
У меня подобная проблема которая тут обсуждалась. Ответа на вопрос я не нашёл и поэтому повторяю :
Remote Management Module key : Installed
Device (BMC) Available : Yes
BMC FW Build Time : 2018-06-07 11:48:53
BIOS ID : SE5C610.86B.01.01.0027.071020182329
BMC FW Rev : 1.53.11210
Boot FW Rev : 1.07
SDR Package Version : SDR Package 1.17
Mgmt Engine (ME) FW Rev : 03.01.03.050
Baseboard Serial Number : BQTP61800321
Сенсоры в BMC WEB console :
VRD Hot All deasserted OK 0x0000
DIMM Thrm Mrgn 1 Normal OK -48 degrees C
DIMM Thrm Mrgn 2 Normal Unknown Not Available
DIMM Thrm Mrgn 3 Normal OK -51 degrees C
DIMM Thrm Mrgn 4 Normal Unknown Not Available
Agg Therm Mgn 1 Normal OK -7 degrees C
Постоянно, приблизительно каждые 5 минут в сфере vmware выходит сообщение о температуре на DIMM. Помогите от этого избавиться.
for english :
Good afternoon !
At me a similar problem which here was discussed. I did not find the answer to the question and therefore I repeat:
Remote Management Module key: Installed
Device (BMC) Available: Yes
BMC FW Build Time: 2018-06-07 11:48:53
BIOS ID: SE5C610.86B.01.01.0027.071020182329
BMC FW Rev: 1.53.11210
Boot FW Rev: 1.07
SDR Package Version: SDR Package 1.17
Mgmt Engine (ME) FW Rev: 03.01.03.050
Baseboard Serial Number: BQTP61800321
Sensors:
Constantly, approximately every 5 minutes in the vmware sphere there is a message about the temperature on the DIMM.
help please get rid of it.
0 積分
27 回應
員工
5,241 檢視
Hello rs-link,
Hope you are doing fine.
In order to better assist you can you confirm the motherboard model?
Charlie_Intel
RSmir
初學者
5,241 檢視
Processed Tags
FRU & SDR Update Package for Intel(R) Server Board S2600TPx (S
2600TP_117)
Copyright (c) 2017 Intel Corporation
Intel(R) Server Board S2600TPR detected
Auto-detecting chassis model and attached hardware.
This may take up to 1 minute to complete.
NODE Presence is present
Detected Hardware
Intel(R) Server Chassis H2000G Product Family
Intel(R) Xeon(R) Processor E5-2600 in socket 1
Intel(R) Xeon(R) Processor E5-2600 in socket 2
Baseboard FRU Device
1600 Watt Power Supply Module 1
Power Supply Module 1 FRU Device
1600 Watt Power Supply Module 2
Power Supply Module 2 FRU Device
Redundant Power Supply Configuration
HSBP is a 2U 12 slot 3.5 inch HDD Backplane
IO Module FRU Storage Device
IO Module Temperature Device
員工
5,241 檢視
Hello rs-link,
Are able to restart the server?
Can you perform a CMOS clear and system event log clear just for testing purposes?
Charlie_Intel
RSmir
初學者
5,239 檢視
Good afternoon !
Yes of course I will. Tomorrow I'll be in the server room, I'll write.
Thank you.
員工
5,241 檢視
Hello rs-link,
Thank you, let us know how it goes.
Charlie_Intel
RSmir
初學者
5,241 檢視
After completing your instructions, the day passed - the flight was normal. Sphere does not give out more warnings about the memory temperature. Tomorrow I'll cut the computational modules into combat mode - let's see.
Many thanks for the advice.
With the best wishes.
RSmir
初學者
5,241 檢視
Good afternoon !
Unfortunately the messages have again climbed. Confuses this:
DIMM Thrm Mrgn2 and Mrgn4
RSmir
初學者
5,241 檢視
In addition to the complete information, a message from vsphere:
員工
5,240 檢視
Hello rs-link,
Is there a way that you can share the sysinfo logs from the server with us so we can perform a deep research about it?
With the last image what we can see is a failing sensor, but we would like to sure about it.
Charlie_Intel
RSmir
初學者
5,241 檢視
Good evening !
I attach the report generated for developers in the form of an archive file with logs. I hope that helps.
員工
5,240 檢視
Hello rs-link,
Thanks for the file, unfortunately, the file is encrypted and we were not able to open it.
Also, the one that we require is the sysinfo log, you can pull it out by following this link: https://www.intel.com/content/www/us/en/support/articles/000023940/server-products/server-boards.html
Please let us know if you need further assistance to download the logs.
Charlie_Intel
RSmir
初學者
5,240 檢視
The prose of life is that I do not encrypt this file, but your hardware. Anyway. Attached files with logs taken by sysinfo. I really hope that helps. Look forward to.
In advance, I'm sorry for my English.
員工
5,241 檢視
Hello rs-link,
Do not worry.
Thank you for the file, are you able to switch memories 1 and 2, clear the Cmos again and then send us the new logs?
Charlie_Intel
RSmir
初學者
5,241 檢視
Good afternoon !
The memory is replaced in the following order
DIMM A1 <---> F1
DIMM B1 <---> E1
Cross crosswise.
CMOS reset
Logs are attached.
Thank you in advance
員工
5,241 檢視
Hello rs-link,
Thank you for the information, let us do a quick research about it and we will contact you back.
Charlie V.
RSmir
初學者
5,241 檢視
Good afternoon !
How's it going with my problem? Do not forget about me?
員工
5,241 檢視
Hello rs-link,
Please do not worry we are just waiting for a second level response and we are going to get back to you as soon as possible. Thank you.
Charlie_Intel
員工
5,241 檢視
Hello rs-link,
Thank you for your patience, these values are not memory temps but actual margins or thresholds.
What I did notice in the log is processor IERR. This is an internal processor error and 2 mins after that I see warning events for DIMM Thrm Mrgn failures.
Could be related to processor since processors include the memory controller in them.
Now, the entries are from 09/02 and I don't see them happening anymore.
Could you confirm if the issues are still showing?
I would like you to check the newer logs, is that possible?
Charlie_Intel
員工
5,241 檢視
Hello rs-link,
We are wondering if you need further assistance?
Charlie_Intel
員工
5,104 檢視
Hello rs-link,
Any update?
Charlie_Intel
回覆
