5181 Discussions
problem to config AMT on Intel SE7501WV2
I have an Intel SE7501WV2, but i'm not able to access to AMT bios to config IP address, anyone can help me? the setup isnt' in the normal bios!
I need it because in the past anyone setup a DMZ IP for AMT use (I suppose) and now I not able to use this IP for other utilization.
thanks
DV
Hi there,
I dont think that this board supports Intel Active Management Technology. This board has a Baseboard Management Controller.
Website: http://download.intel.com/support/motherboards/server/se7501wv2/tps.pdf http://download.intel.com/support/motherboards/server/se7501wv2/tps.pdf
Page 54/169
Probably, you will need to configure the BMC.
All the best,
Aryan
thanks for reply; suppose this board don't support AMT, but the IP used by BMC, how I can change this IP config of BMC? I don't find anything in BIOS documentation...
DV
Hi there,
Okay firstly, apologies for the delay.
Well, to configure the BMC of a Board, usually, I have used Intel Deployment Assistant CD or Intel Active Console or System Configuration Utilities for new Board 5000 chipsets.
Since I have never used your board, I cannot give an exact answer for your one.
Possibly the server management software allows you to do that.
Intel Server Mgt
http://downloadcenter.intel.com/scripts-df-external/Detail_Desc.aspx?agr=N&Inst=Yes&ProductID=926&DwnldID=694 http://downloadcenter.intel.com/scripts-df-external/Detail_Desc.aspx?agr=N&Inst=Yes&ProductID=926&DwnldID=694
CLI AutoConfig [AUTOSERVERCFG.TAR.GZ]
http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=904&DwnldID=4999&url=/4999/eng/AUTOSERVERCFG.tar.gz&PrdMap=&strOSs=All&OSFullName=AllOperatingSystems&lang=eng http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=904&DwnldID=4999&url=/4999/eng/AUTOSERVERCFG.tar.gz&PrdMap=&strOSs=All&OSFullName=AllOperatingSystems&lang=eng
Unfortunately, i dont know more than that for this one.
All the best,
Aryan
