5175 Discussions
s2600cp4 in coolermaster stc-t01 cannot get it to work
NBehr
I'm trying to get an intel s2600cp4 board with two e5-2620 processors and 64gb of memory to start up in an coolermaster stc-t01, but the front panel connectors seem to not function properly or maybe the case is too old for this mainboard ?
I'm hoping someone here can give me some pointers, guidance.....
Nico
Edward_Z_Intel
For front panel pin-out, you can refer to http://www.intel.com/support/motherboards/server/sb/CS-028813.htm http://www.intel.com/support/motherboards/server/sb/CS-028813.htm, or the http://www.intel.com/support/motherboards/server/s2600cp/sb/CS-033128.htm Technical Product Specification.
I'm not familiar with this chassis, but seems it's not designed for server boards (it follows ATX/BTX standard, not SSI standard).
It's highly recommended that you check http://www.intel.com/support/motherboards/server/s2600cp/sb/CS-033291.htm Chassis Compatibility and choose a chassis from the list.
