5181 Discussions
what are the responsibilities of each pins in CPU?
hello, my teacher gave me an assignments about the pins of an CPU?
Why is there ,many pins in a CPU instead of only one.
wish you will help me.
thank you.
William_L_Intel1
Hi Nycxzon,
Thanks for your question. Since Intel produces many different types of CPU, there is no one answer to fit all. For example, some CPU have pins that insert into a socket and others have bumps or BGA (Ball Grid Array) and the pins are in the socket.From a very basic point of view, all CPU contain some combination of address, data, power, clock, and other synchronization connections. If you were interested for example in the Pentium 4 CPU, here is the http://www.intel.com/assets/pdf/datasheet/310308.pdf Specification that will explain all the pin connections. Then when you want to take the next step, visit the http://support.intel.com/support/processors/ Intel Processor Support Page and dig into some of the more advanced multi-core designs such as Core2, XEON, and Itanium. Please let us know if this helped to get you a good grade in your class.
Admin
