5226 Discussions
what's the meaning of 'w' in CPU 5500 series W5590 and W5580?
Could you please tell me the meaning of 'w' in CPU 5500 series W5590 and W5580??
Is that meaning workstation??
http://www.intel.com/cd/channel/reseller/asmo-na/eng/products/server/processors/5500/feature/index.htm http://www.intel.com/cd/channel/reseller/asmo-na/eng/products/server/processors/5500/feature/index.htm
Note: The Intel® Xeon® processor W5580 is designed for workstation use only and not intended for server applications or environments.
I didn't find 'W' in the site as below.
http://www.intel.com/products/processor_number/about/xeon_itanium.htm http://www.intel.com/products/processor_number/about/xeon_itanium.htm
Alpha Prefix
zhouyao,
You're correct about the W indicating for workstation use.
X=Extreme/Performance, E=Enterprise, L=Low Power, W=Workstation. Letter designation as part of server & workstation processor numbers are to help with identification of usage segments. The best approach is to review your server application and then determine if you need raw performance, high transaction rates, etc. Then you can choose a processor that best meets your requirements. The letters are there to help classify segment areas.
John
