884 Discussions
Do DPC++ compiler support stdcall convention
NickVilson
标准 dll 入口点函数的调用约定为stdcall,这样,dll才能为第三方程序调用,如labview 应用,但DPC++ 编译器不能支持stdcall,用它编译的dll不能被第三方程序和C++应用调用,怎么解决这个问题呢?
VaishnaviV_Intel
Thank you for posting your question. We only provide support in English. I have translated your question. “The standard DLL entry point function is called by stdcall, so that the DLL can be called by a third-party program, such as a Labview application, but the dpc++ compiler cannot support stdcall, and the DLL compiled with it cannot be called by a third-party program and a C++ application, how to solve this problem?”
Does this reflect your question correctly?
Thanks & Regards,
Vankudothu Vaishnavi.
VaishnaviV_Intel
We haven't heard back from you, Could you please let us know if the above translation reflects your query correctly?
Thanks & Regards,
VaishnaviV_Intel
We haven't heard back from you. If you have any issues, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
