reply to "cant load dpc++ compiled dll"
NickVilson
Hello sir.
Thank you for your answer. Yes, it works according to your advice. but the lib can't be load by NI's Labview.  I think it maybe the issue of using labview.
 I try to reply to you under the topic, but after try many times, including through google explore, because the "reply button" is disabled in Microsoft edge and google explore. sorry for reply later. Best wishes! Nick
VaishnaviV_Intel
As you are referring to https://community.intel.com/t5/Intel-oneAPI-Base-Toolkit/cant-load-dpc-compiled-dll/m-p/1540193#M3210 thread, Do you still have any issues with any of the Intel oneAPI products? If not, could you please confirm if we can close this from our end?
And regarding https://community.intel.com/t5/Intel-oneAPI-Data-Parallel-C/Do-DPC-compiler-support-stdcall-convention/m-p/1540599#M3388 thread, as it is a translation query and through intel translation tool we got to know that it’s the same query as the above one. So, could you please confirm if we can mark this particular thread as duplicate?
Thanks & Regards,
Vankudothu Vaishnavi.
VaishnaviV_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
