공지
HWPGO wih child process
Version001
새로운 기여자 I
2,046 조회수
I want to try HWPGO but I have a problem. My program creating a child process so if I run analyzing, its stuck at Executing process. Is there is any env. flag for analyzing child process?
Thanks!
0 포인트
9 응답
Tim_C_Intel
직원
1,944 조회수
Child process sampling behavior depends on which profiling tool you're using for the binary-level sampling.
Unfortunately, if you're using SEP then the "-app" argument serves as the target for internal sample filtering. This means that if the executable named by "-app" launches a different executable then samples in for the child process will be filtered out. For the moment the only workaround is to launch the child process of interest directly with SEP's "-app" and "-args" options.
This something we'd like to improve, possibly by providing a post-mortem HWPGO conversion/filtering tool for SEP's native tb7 output.
If using "perf" (on Linux) the effective filtering should include child processes by default.
With that said, SEP should not hang. Is that what you're seeing? If so, can you share how you're invoking it?
0 포인트
Version001
새로운 기여자 I
1,932 조회수
I build with this args (see 1.png) and when running test, my app running but execution process not finishing (see 2.png)
0 포인트
Tim_C_Intel
직원
1,896 조회수
Thanks. Two follow-up questions:
  1.  When stuck as shown in 2.png, is the TargetPath executable and/or the child process it launches still executing? Are one or both of them using CPU? You may need to consult Task Manager or similar.
  2. Do results change if you use "/fprofile-sample-generate=keep-all-opt" in 1.png and re-compile/re-profile?  I'd advise against "max-fidelity" as this disables virtually all optimizations, and it does not typically improve profile fidelity.  (It's mainly useful for identifying cases where optimizations interfere with feedback, but this is the exception.)
0 포인트
Version001
새로운 기여자 I
1,879 조회수
I tried fprofile-sample-generate=keep-all-opt now but its same.
for 1. question, yes my program opening and running normally..
0 포인트
Tim_C_Intel
직원
1,862 조회수
At this sampling period SEP should not significantly slow or halt the application. Is the application expected to perform some computation and then exit on its own?
When the hang is happening, are both the parent and child process still running?
Have you been able to successfully run the collection (without hang) with a project without the child process arrangement?
0 포인트
Version001
새로운 기여자 I
1,818 조회수
My app is a game, its creating a Python thread with C API for GUI. My game running normally, so problem is just executing not finishing, so hwpgo cant collect infos.
(my game works normally even if the analysis execution gets stuck)
0 포인트
Tim_C_Intel
직원
1,728 조회수
Have you been able to successfully run the collection (without hang) with a project without the child process arrangement? I am trying to confirm that SEP is working.
If so, could you try profiling your game by invoking it via sep on the command line?
0 포인트
Version001
새로운 기여자 I
1,670 조회수
Yea the problem is probably visual studio based. I can successfully analyze my app via command line..
0 포인트
Tim_C_Intel
직원
1,474 조회수
Thanks. Yes, it sounds like there is an issue in the Visual Studio plugin's ability to collect the binary profile.
As a workaround you could try to:
1. Produce perf.script output via sep on the command line. Use the options pre-populated in the Visual Studio HWPGO dialogue boxes.
2. Manually invoke llvm-profgen to convert the binary-level profile (perf.script) to an LLVM source-level profile.
3. Finally, select/run only the 3rd phase of HWPGO in Visual Studio where you point the compiler to this profile with "/fprofile-sample-use".
Details on how to run llvm-progen with 2024.2 are available here:
https://www.intel.com/content/www/us/en/docs/dpcpp-cpp-compiler/developer-guide-reference/2024-2/hardware-profile-guided-optimization.html
0 포인트
응답
