891 Discussions
Intel oneAPI setvars.sh does not work for not root user oneAPI 2022.1.0 (2022.1.0.20220316)
AnandKulkarniSG
I setup oneAPI 2022.1.0 (2022.1.0.20220316) on my fedora 31 distribution in path /opt/intel/ via offline method and deployed the installation as a root user.  I want to be able to setup the dev env and used the source /opt/intel/oneapi/setvars.sh intel64 as well as source /opt/intel/oneapi/setvars.sh to no effect. Both throw error from script ( log details attached ).
As a root user if i run the same commands it works ( details in log again ).
Is there a simple guide/command for non root users to import the setvars.sh settings ? I have to manually otherwise do the below currently to be able to use tbb and dpcpp ( via my .bashrc settings as a non root user ).
# setup intel oneapi pstl,tbb and c++ development env.
export INTEL_ONEAPI_PATH=/opt/intel
export INTEL_ARCH=intel64
source ${INTEL_ONEAPI_PATH}/oneapi/compiler/latest/env/vars.sh $INTEL_ARCH
source ${INTEL_ONEAPI_PATH}/oneapi/dpl/2021.7.0/env/vars.sh $INTEL_ARCH
source ${INTEL_ONEAPI_PATH}/oneapi/tbb/2021.6.0/env/vars.sh $INTEL_ARCH
Viet_H_Intel
Not sure what happened at your end, but it worked from my end.
AnandKulkarniSG
Please don't reply to this thread saying fedora 31 isn't supported. This issue is at the script/bash level and hence whether it is fc31 or fc35 doesn't matter. Also, it works under the root user id but does not work under a nonroot regular developer user id.
SeshaP_Intel
Could you please try the below command to execute for normal users(non-root users).
. ${INTEL_ONEAPI_PATH}/oneapi/setvars.sh
Please refer to the below link for more details.
https://www.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-dlfd-linux/top/before-you-begin.html
Thanks and Regards,
Pendyala Sesha Srinivas
AnandKulkarniSG
I hope this helps. It does not work. period!
AnandKulkarniSG
@SeshaP_Intel  Any updates ?
Viet_H_Intel
AnandKulkarniSG
See if this makes any sense at all. I finally solved it with the help of article : https://community.intel.com/t5/Intel-C-Compiler/How-to-use-zsh-csh-or-tcsh-with-oneAPI-setvars-sh-vars-sh-or/m-p/1227218/thread-id/37878
anand@ldnpsr2937 ~]$source ${INTEL_ONEAPI_PATH}/oneapi/setvars.sh ${INTEL_ARCH}
bash: /opt/intel/oneapi/setvars.sh: line 95: syntax error near unexpected token `('
bash: /opt/intel/oneapi/setvars.sh: line 95: `usage() {'
[anand@ldnpsr2937 ~]$source /opt/intel/oneapi/setvars.sh intel64
[anand@ldnpsr2937 ~]$bash -c "source /opt/intel/oneapi/setvars.sh intel64"
:: initializing oneAPI environment ...
bash: BASH_VERSION = 5.0.17(1)-release
args: Using "$@" for setvars.sh arguments: intel64
:: advisor -- latest
:: ccl -- latest
:: compiler -- latest
:: dal -- latest
:: debugger -- latest
:: dev-utilities -- latest
:: dnnl -- latest
:: dpcpp-ct -- latest
:: dpl -- latest
:: intelpython -- latest
:: ipp -- latest
:: ippcp -- latest
:: ipp -- latest
:: mkl -- latest
:: mpi -- latest
:: tbb -- latest
:: vpl -- latest
:: vtune -- latest
:: oneAPI environment initialized ::
AnandKulkarniSG
Does seem very odd. Anyway we can close this issue , i have work around by manually importing setting for each component as discussed above. I will live with that meanwhile.
Viet_H_Intel
Thank for accepted a solution. We won't monitor this thread anymore. If you have any other questions/concerns, please create a new thread.
