LLVM Exception ERROR
psindhi
LLVM ERROR: IO failure on output stream: No space left on device
PLEASE submit a bug report to https://software.intel.com/en-us/support/priority-support and include the crash backtrace.
Stack dump:
0. Program rguments: /mnt/efs/fs1/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/llvm-link -only-needed /tmp/pack_test-6af6cf.bc /tmp/libsycl-crt-ab0e9d.o /tmp/libsycl-complex-30a864.o /tmp/libsycl-complex-fp64-b8940b.o /tmp/libsycl-cmath-3a47ad.o /tmp/libsycl-cmath-fp64-c07b73.o /tmp/libsycl-fallback-cassert-a1fbf8.o /tmp/libsycl-fallback-cstring-8293bf.o /tmp/libsycl-fallback-complex-7671a7.o /tmp/libsycl-fallback-complex-fp64-ce105c.o /tmp/libsycl-fallback-cmath-d1c5c3.o /tmp/libsycl-fallback-cmath-fp64-874723.o -o /tmp/pack_test-0a69d1.bc --suppress-warnings
Stack dump without symbol names (ensure you have llvm-symbolizer in your PATH or set the environment var `LLVM_SYMBOLIZER_PATH` to point to it):
/mnt/efs/fs1/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/llvm-link(+0x3766da)[0x55ed73b5f6da]
/mnt/efs/fs1/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/llvm-link(+0x376b8e)[0x55ed73b5fb8e]
/lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7fdbb711d520]
/lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7fdbb7171a7c]
/lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7fdbb711d476]
/lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7fdbb71037f3]
/mnt/efs/fs1/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/llvm-link(+0x3448a4)[0x55ed73b2d8a4]
/mnt/efs/fs1/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/llvm-link(+0x3618cf)[0x55ed73b4a8cf]
/mnt/efs/fs1/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/llvm-link(+0x1ae4e3)[0x55ed739974e3]
/lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7fdbb7104d90]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7fdbb7104e40]
/mnt/efs/fs1/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/llvm-link(+0x1acbe9)[0x55ed73995be9]
dpcpp: error: unable to execute command: Aborted (core dumped)
dpcpp: error: sycl-link command failed due to signal (use -v to see invocation)
Intel(R) oneAPI DPC++/C++ Compiler 2022.1.0 (2022.1.0.20220316)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /mnt/efs/fs1/intel/oneapi/compiler/2022.1.0/linux/bin-llvm
dpcpp: note: diagnostic msg: Error generating preprocessed source(s) - no preprocessable inputs.
SantoshY_Intel
Could you please provide us with a sample reproducer code and the steps to reproduce your issue? Also, please provide your environment details such as the target Operating system & target devices(CPU/GPU/FPGA) being used to reproduce your issue.
We can see that you are a priority support customer. So, you can post your query in the below link for priority support:
https://www.intel.com/content/www/us/en/developer/get-help/priority-support.html
Thanks & Regards,
Santosh
SantoshY_Intel
We haven't heard back from you. Could you please provide us with any updates on your issue?
Thanks & Regards,
Santosh
SantoshY_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Santosh
