801 Discussions
OpenMP pragma: omp smid not recognized by dpcpp
Tomasoni
Hello all.
dpcpp compiler is warning me about a missing omp directive
matrixLib.c:395:14: error: expected an OpenMP directive
#pragma omp smid
in the following code
#pragma omp smid
for(int i=start; i<=end ; i += step)
   out_vector[midx++] = i;
But I read here
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top/optimization-and-programming/openmp-support/openmp-pragmas.html
that omp smid directive is supported.
this works if compiled with gcc-9 or g++-9
Can you explain me what is the right directive with dpcpp?
Danilo
VarshaS_Intel
Could you please try using the 'pragma omp simd' since it is a supported directive with the dpcpp compiler? Please find the below link:
We have tried a sample code and it worked without any errors. Please find the below screenshot:
Could you please elaborate on how to use 'pragma omp smid'?
And also, could you please let us know the Intel DPCPP compiler version, OS details, and sample reproducer code to investigate more on your issue?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards.
Varsha
Tomasoni
Hello, thank you for your answer. I think I was missing `-qopenmp` while compiling with dscpp
I couldn't find this in the docs.
Thank you!
VarshaS_Intel
Could you please find the below link where we are able to compile and run OpenMP code with dpcpp compiler:
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-programming-guide/top/software-development-process/composability/c-c-openmp-and-dpc-composability.html
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Varsha
