882 Discussions
Unable to work with 4 Dimensional data for batch2d program in dpc++
Pranathi_R
Hello team,
I was trying to run my codes parallelly using dpcpp, but I am facing some issues, my input data is 4 dimension but while using buffer it is not accepting 4D data and throwing following error,  static_assert failed due to requirement '4 >= 1 && 4 <= 3' "range can only be 1, 2, or 3 dimensional." . So, Do you have any alternative to work on 4D data.
Thank you,
Pranathi R
NoorjahanSk_Intel
Could you please provide us with a sample reproducer and compiler version?
Also, please provide the OS details so that we can try it from our end.
Thanks & Regards,
Noorjahan.
Ethan_F_Intel
There are a number of ways one can process 4 dimensional data even despite buffers being limited to three dimensions.
It all is a matter of understanding what you are trying to do, and designing an algorithm which achieves this.
For example, you could store all your data in a 1 dimensional array, but index it in a way to simulate four dimensions.
More details on that here: 4d-position-from-1d-index
Another way is to store the data in a 1D list of 4D tuples.
I have provided an example of this using DPC++ in the attached file.
Ethan_F_Intel
Has your issue been resolved? If I don't hear from you within 5 business days, I will assume your support request is resolved. 
Ethan_F_Intel
After case closure, you will receive a survey email. We appreciate it if you can complete this survey regarding the support you received.
