886 Discussions
Problem using ndrange with Intel Graphics
QM
I am using DPC++ to enable parallelization for my code. Using sycl::ndrange<1>{N, worker_number} works totally fine when run on CPU (using sycl::host_selector{}). However, when I switch to Intel graphics by using sycl::default_selector{}, the errors are caused by the use of ndrange ( switch to range approach works). Does anybody know what's wrong with it?
Here is details of my dpcpp version:
-Intel(R) oneAPI DPC++/C++ Compiler 2022.0.0 (2022.0.0.20211123)
-Target: x86_64-pc-windows-msvc
-Thread model: posix
Q
QM
I have posted this question to Intel OneAPI DPC++ forum as I believe it's more related there. But if anybody know the issue, please let me know.  Thank you.
Ben_A_Intel
Hi, what are your nd_range dimensions?  Specifically, what is the value of worker_number in the code snip above?
GPUs (and other types of accelerators) have limits on the maximum size of the local range (AKA "work-group size"), and if you are exceeding the device maximum you will get an error.
If you're sure that the value of worker_number is supported by your GPU can you please send additional information about the error you are seeing?  Thanks!
QM
Hi Ben,
Thanks for your reply,  local range is previously set at 64, then I changed it to 1, but still does not work. The error message is blank, yeah funny, but honestly, blank. Switching to sycl::host_selector{} and it works perfectly.
Ben_A_Intel
Can you run your test with oneTrace enabled, especially with the CallLogging option ("-c")?  This might provide more hints why the error is occurring.
https://github.com/intel/pti-gpu/tree/master/tools/onetrace
If you can send the exact error you are seeing this will help also.  Thanks!
SantoshY_Intel
We have not heard back from you. As suggested by @Ben_A_Intel , could you please try running your test with oneTrace and send the exact error you are seeing?
Thanks & Regards,
Santosh
SantoshY_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Santosh
