855 Discussions
boost 1.79.0 link issue with oneApi 2022.0.0.20211123
bruce_spc
Trying to build and link the latest boost libraries (boost 1.79.0) using the oneAPI Intel C++ compiler (2022.0.0.20211123) in Visual Studio 2019 (Version 16.11.11).
1) I previously installed the oneAPI C++ compiler and toolset and integrated into Visual Studio as instructed. This worked.
2) I followed the guidance for building the boost libraries in this article
Building Boost* with Intel® oneAPI .
I used this command line:
b2 install --prefix=D:\Tools\boost\boost_1_79_0\stage --without-python --without-graph_parallel --without-mpi toolset=clang-win link=static address-model=64 architecture=x86 runtime-link=static
The libraries get built and installed into the folder specified. HOWEVER, they have this format:
     libboost_<xyzlib>-clangw2022-mt-sgd-x64-1_79.lib
3) When I try to link my C++ program in Visual Studio using the Intel Compiler it gives me a link error:
LNK1104 cannot open file 'libboost_<xyzlib>-clangw14-mt-sgd-x64-1_79.lib'
I can cause the link to succeed by renaming all the libraries to clangw14, but surely there is a better way to get this done.
Bruce
VidyalathaB_Intel
Since the linker is searching for files with clangw14 (not sure with the exact reason but in common.jam file located in tools\build\src\tools it is written as: On Intel, version is not added, because it does not matter and it is the version of vc used as backend that matters) as toolset tag, maybe we could try changing the configuration settings as
using clang-win : 14 : "C:/Program Files (x86)/Intel/oneAPI/compiler/latest/windows/bin-llvm/clang-cl.exe" ;
in project-config.jam file located in the boost-root folder. After this change, you can proceed with b2 install step.
In this way instead of renaming all the files manually, the files will get generated with clangw14 toolset tag.
Please let me know if you face any issues in doing so.
Vidya.
VidyalathaB_Intel
Vidya.
bruce_spc
Hi, Vidya. This solution worked. Thanks for the help.
VidyalathaB_Intel
Reminder:
As we haven't heard back from you, could you please provide us with an update regarding your issue?
Vidya.
NoorjahanSk_Intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Thanks & Regards,
Noorjahan.
