842 Discussions
how to test use oneapi dpc++/c++ compiler can help my applications to run faster
liu_wei67
hi:
i am a novice. can show me a simple demo and process?
thanks
NoorjahanSk_Intel
DPCPP supports applications to run on heterogeneous processors to be written using standard ISO C++ with the host and kernel code for an application contained in the same source file.
Please refer to the below link for more details regarding the dpc++ compiler:
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top.html
DPCPP makes use of GPU to run the application faster. It selects the default device present in your system.
You can get the devices present in the system using the below command
>sycl-ls
You can also specify the device type and backend on which you wanted to run your application using the below command
>SYCL_DEVICE_FILTER=opencl:cpu
>SYCL_DEVICE_FILTER=level_zero:gpu
Please refer to the below link for more details:
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-programming-guide/top/oneapi-programming-model/device-selection.html
We have tried a sample vector add program using the dpcpp compiler.
You can get the samples from the below link:
https://github.com/oneapi-src/oneAPI-samples.git
>git clone https://github.com/oneapi-src/oneAPI-samples.git
>cd oneAPI-samples/DirectProgramming/DPC++/DenseLinearAlgebra/vector-add/
>make
>./vector-add-buffers
Please find the below screenshot for more details.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We haven't heard back from you.
Has the information provided above helped? If yes, could you please confirm whether we can close this thread from our end?
Thanks & Regards,
Noorajahan
liu_wei67
NoorjahanSk_Intel
>>thank you very much.
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Thanks & Regards,
Noorjahan.
