Here I use this data set: http://archive.ics.uci.edu/ml/datasets/Statlog+(Landsat+Satellite)
There's 1-7 classes but class 6 is empty so I change the class label to 0-5
My code is attached and the question is the result of the prediction is not so well. Even cannot reach 50%.
So maybe there's some mistake in my code. Thanks for your help.
BTW, parameters like accuracyThreshold and nIteration in optimization solver maybe are not used? When I changed these parameters and the prediction results are the same. Is there any stopping criteria for us to use?
Hi Hanxi,
You are right, the present version of the library does not use the parameters such as the number of iterations and the accuracy threshold for the neural network training. You may change the batch size or learningRate to see if there any different.
We will investigate the problem and get back to you later.
Ying
Hi Hanxi,
We have seen same low accuracy with your original code on our side so there are no mistakes in your code. However you can get better accuracy with Satellite dataset and Neural Network topology by applying the following techniques:
- Change Neural Network initializer from uniform to Xavier
fullyConnectedLayer1->parameter.weightsInitializer.reset(new initializers::xavier::Batch<>()); fullyConnectedLayer2->parameter.weightsInitializer.reset(new initializers::xavier::Batch<>());
- Increase hiddenNeurons from 10 to 20 and batchSize parameter from 10 to 128
const int hiddenNeurons = 20; const size_t batchSize = 128;
- Split dataset in batches and add additional epochs to training stage
for (size_t epoch = 0; epoch < 400; epoch++) { for(size_t i = 0; i < nBatches; i++) { net.input.set(training::data, trainingDataArray); net.input.set(training::groundTruth, trainingGroundTruthArray); net.compute(); } }
In addition to it you can also shuffle the data that also contribute to better accuracy. As a result we were able to achieve accuracy of 0.795. Please find modified example and datasets attached.
Let us know if it will not help you.
Thank you and happy holidays!
-Daria
Really appreciate for your help.
I'm working on your feedback and will follow up in a few days.
Hi Daria,
I've followed your code and tested for a few of things, and the accuracy result performed on my machine is 0.7915.
1. I added two declaration about biases initializer
fullyConnectedLayer1->parameter.biasesInitializer.reset(new initializers::xavier::Batch<>());
fullyConnectedLayer2->parameter.biasesInitializer.reset(new initializers::xavier::Batch<>());
The accuracy reduced to 0.7905. Why?
2. How to get appropriate batchSize? I've tested a few batchSize. Here's the result.(with no biases initializer)
batchSize accuracy
10 0.7940
20 0.8000
50 0.7905
128 0.7915
500 0.7610
4435 0.7435
3. I want to make this neural network random, so I add these two sentences.
srand(time(NULL));
sgdAlgorithm->parameter.seed = rand();
But I found no changes, is this parameter no use or I've made a mistake?
Thanks a lot for your help.
Hanxi
Hi Hanxi,
Quality of the neural network training is defined by multiple parameters including initialization, learning rate, batch size etc. Search of the optimal values for those parameters is important stage in the training of the model and requires some effort what was also confirmed by results of your experiments. By default, parameters of the neural network, weights and biases, are initialized using uniform initializer (-0.5; 0.5). Use of the default initializer for bias demonstrates better accuracy results in your topology and dataset.
Similarly, the batch size that equals to 20 results in the better training accuracy. By the way, the common observation in choice of batch size is as following: with smaller batch size you may get less accuracy while using the bigger batch size can result in longer training time. The model parameters are updated for each batch after each iteration using optimization solver such as SGD (thus, if size of batch equals to the size of the dataset, only one parameter update will be completed).
Neither seed nor nIterations and accuracyThreshold parameters are used during the parameter update (see also https://software.intel.com/en-us/forums/intel-data-analytics-acceleration-library/topic/705133).
Please, use learningRate parameter of the optimization solver to see any effect on the neural network model training.
Let me know about any results of the experiments with neural network training on your side or if you have additional comments or questions.
-Daria
Hi Hanxi,
Please, have a look at the additional details for use of learningRate parameter during neural network training.
Hope it helps,
-Daria
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
