BUG for in-place forward DFTs ??
OP1
New Contributor III
The following simple program does not produce the correct results. It's behavior actually seems to be some times correct, most of the times wrong, when you run it several times, consecutively!
It is a simple forward transform of two identical sets of datas (DFTI_NUMBER_OF_TRANSFORMS is > 1) stored consecutively in the same 1D array (TIME_DATA). The two data sets (8 time points each) correspond to a simple cosine signal.
The forward transform for thefirst data set is always properly calculated. The second transform is wrong most of the time.
Can somebody shed some light on this? I have to add that if I do not specify inplace transforms, then it works. Oh, and it seems I just can't use DFTIFREEDESCRIPTOR without having my code crashing. What is going on? I am using IVF 10.1 and the MKL 10.1 Beta (the same behavior was observed with MKL 8.1).
Thanks in advance! This is very puzzling (and frustrating...)
PROGRAM
TEST
USE
MKL_DFTI
IMPLICIT NONE
INTEGER(4)
,PARAMETER :: N_TIME = 8
INTEGER(4)
,PARAMETER :: N_SETS = 2
INTEGER(4)
I,J,S1,S2,S3,S4,S5,S6,S7,ERROR
REAL(8)
PI,T,TIME_DATA(1:2*N_TIME)
TYPE
(DFTI_DESCRIPTOR),POINTER :: DH
DO
J=1,N_SETS
DO I=1,N_TIME
T = (8.0D+0*
DATAN(1.0D+0)*DBLE(I-1)/DBLE(N_TIME))
TIME_DATA((J-1)*N_TIME+I) =
DCOS(T)
ENDDO
ENDDO
WRITE
(*,'(20F5.1)') TIME_DATA
S1 = DFTICREATEDESCRIPTOR(DH,DFTI_DOUBLE,DFTI_REAL,1,N_TIME)
S2 = DFTISETVALUE(DH,DFTI_NUMBER_OF_TRANSFORMS,N_SETS)
S3 = DFTISETVALUE(DH,DFTI_PLACEMENT,DFTI_INPLACE)
S4 = DFTISETVALUE(DH,DFTI_INPUT_DISTANCE,N_TIME)
S5 = DFTISETVALUE(DH,DFTI_OUTPUT_DISTANCE,N_TIME)
S6 = DFTICOMMITDESCRIPTOR(DH)
S7 = DFTICOMPUTEFORWARD(DH,TIME_DATA)
WRITE
READ
END
PROGRAM
Todd_R_Intel
To use CCS storage with the INPLACE algorithm you will need to add padding. That will involve changing N_TIME to (N_TIME/2+1)*2 in several places. Give the following changes a try (- = remove the line, + = add the line):
--- y.f90   2008-08-07 23:45:42.161126300 +0700
+++ z.f90 2008-08-07 23:47:20.551121600 +0700
@@ -4,22 +4,23 @@
INTEGER(4),PARAMETER :: N_TIME = 8
INTEGER(4),PARAMETER :: N_SETS = 2
INTEGER(4) I,J,S1,S2,S3,S4,S5,S6,S7,ERROR
-REAL(8) PI,T,TIME_DATA(1:2*N_TIME)
+REAL(8) PI,T,TIME_DATA(1:2*(N_TIME/2+1)*2)
TYPE(DFTI_DESCRIPTOR),POINTER :: DH
DO J=1,N_SETS
DO I=1,N_TIME
T = (8.0D+0*DATAN(1.0D+0)*DBLE(I-1)/DBLE(N_TIME))
-TIME_DATA((J-1)*N_TIME+I) = DCOS(T)
+TIME_DATA((J-1)*(N_TIME/2+1)*2+I) = DCOS(T)
ENDDO
ENDDO
WRITE(*,'(20F5.1)') TIME_DATA
-S4 = DFTISETVALUE(DH,DFTI_INPUT_DISTANCE,N_TIME)
-S5 = DFTISETVALUE(DH,DFTI_OUTPUT_DISTANCE,N_TIME)
+S4 = DFTISETVALUE(DH,DFTI_INPUT_DISTANCE,(N_TIME/2+1)*2)
+S5 = DFTISETVALUE(DH,DFTI_OUTPUT_DISTANCE,N_TIME/2)
-READ(*,*)
+S7 = DFTIFREEDESCRIPTOR(DH)
+PRINT *,"End"
END PROGRAM
Output of the fixed program is:
  1.0  0.7  0.0 -0.7 -1.0 -0.7  0.0  0.7  0.0  0.0  1.0  0.7  0.0 -0.7 -1.0 -0.7  0.0  0.7  0.0  0.0
0.0 0.0 4.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 4.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
End
OP1
New Contributor III
Thanks a lot!! This does the trick... It probably also explains the erratic behavior of my code (since the MKL subroutines were manipulating arrays that they thought were longer than their actual size).
This being said... would it be possible to implement a test in DftiCommitDescriptor that would check the compatibility of the arguments set with DftiSetValue and the length of the arrays (when Dfti_Inplace is used)? It seems it's areally easy mistake to do!
Well, thanks again!
Todd_R_Intel
Yeah, that might be worthwhile. I'll pass your suggestion along. -Todd
