DGEMM inconsistent result
Viet-Duc
  • Library version: 2021.3
  • OS info and version: CentOS 7.9.2009
  • Compiler verison: icc version 2021.3.0 (gcc version 4.8.5 compatibility)
  • MKL linking command:
icc -O2 -std=c11 -mkl=sequential -L$MKLROOT/lib/intel64 dgemm.c -o dgemm.x
Dear Support Team,
I am measuring performance of matrix multiplication using dgemm().
The code to reproduce the issue is attached. dgemm() was invoked as following:
dgemm("N", "N", &m, &n, &p, &alpha, A, &p, B, &n, &beta, C, &n);
The example is a simple 3x3 multiplication. In the source code, there are two ways to initialize A and B. I marked these two methods with approriate comments in the file.
  • Double casting of interger: this gives correct C
  • Random number between (0,1]: this gives incorrect C
To rule out the possibility of thread interference, I linked with the sequential version of the library.
The file 'correct.txt' is the expected output for randomized input matrices.
The file 'incorrect.txt' is the result I obtained with dgemm() for randomized input matrices
I appreciate if you can point me to the origin of this inconsistency.
(For some reason, I could not attach the files using forum, I appologize for the inconvenience)
VidyalathaB_Intel
We tried the provided code from our end and could reproduce the results which you are getting.
But here are some observations:
To check the results we used cblas_dgemm where you will get an option to change the matrix layout (Row Major or Col Major)
Here is the function call
cblas_dgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans, m, n, p, alpha, A, p, B, n, beta, C, n);
By using the above function call, we observed it is giving the correct result (matches with your expected result)
cblas_dgemm(CblasColMajor, CblasNoTrans, CblasNoTrans, m, n, p, alpha, A, p, B, n, beta, C, n);
whereas the above function call gives the output which matches with your incorrect result.
By default dgemm follows the matrix layout as column-major, hence there is a mismatch in your expected and actual results.
Please find the attached file for the code snippet we have tried.
Hope the provided information helped.
Vidya.
VidyalathaB_Intel
Vidya.
Viet-Duc
Dear Vidya,
Thanks for the detailed answer and test. I am able to obtain correct result using cblas_dgemm as you suggested.
Regards.
VidyalathaB_Intel
Thanks for accepting our solution.
As this issue is resolved, we are closing this thread. Please post a new question if you need any additional information from Intel as this thread will no longer be monitored.
Have a Good Day!
Vidya.
