Different Eigenvalues on Different Machines
Samuel_M_1
I am computing eigenvalues on different machines. With the exact same binary and the same shared libraries, I obtain different eigenvalues for near zero entries when I run on different machines. Is this expected behavior?
On a 64 core node:
   -2.7756e-17
   4.2301e-46
   3.4694e-18
   1.7984e-02
   9.4446e-01
On a 32 core node:
   1.8526e-47
   3.4694e-18
   2.7756e-17
   1.7984e-02
   9.4446e-01
I suspect that MKL is auto-threading with different numbers of cores and this is causing the floating point operations to execute in different orders, but would like to make sure.
Gennady_F_Intel
yes, You are right. this is the expected behavior. to eliminate the problem you can try to apply CNR mode.
Gennady_F_Intel
