- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Let covold be a matrix of size 72x72, theta be a vector of size 1x72 and meanold a vector of size 1x72. I want to compute
[(w-1)/w ]* covold + [ 1/(1+w) ] * (theta - meanold)' * (theta - meanold)
where w=144.0.
I wrote a code in C and a code in Matlab in order to compare the results. I noticed that the results are different. For example the variance of the first variable is:
C: 0.001890
Matlab: 0.003690258
I would like to ask if this is normal. I attach the data and the results using Matlab (matlabcov.txt).
Thank you very much.
The code in C is:
#include "stdafx.h"
#include <math.h> /* Math stuff ISOC */
#include <stdio.h> /* I/O lib ISOC */
#include <stdlib.h> /* Standard Lib ISOC */
#include <fstream>
#include <mkl.h>
#include <conio.h>
#include <iostream>
#include <string>
using namespace std;
void fReadMtrx(string f, double *mtrx, int nrow, int ncol);
#define NPARS 72
#define N 144
int main()
int i, j, info, dimen = NPARS;
double meanold[NPARS], covold[NPARS*NPARS], subvec[NPARS], theta[NPARS];
double weight = 144.0;
fReadMtrx("MEAN.txt", meanold, NPARS, 1);
fReadMtrx("thetacan.txt", theta, NPARS, 1);
fReadMtrx("COVFILE.txt", covold, NPARS, NPARS);
/*Update Covariance and Mean */
vdSub(NPARS, theta, meanold, subvec );
cblas_dgemm(CblasRowMajor, CblasTrans, CblasNoTrans, NPARS, NPARS, 1, 1.0/(1.0+weight), subvec,
NPARS, subvec, NPARS, (weight-1.0)/weight, covold, NPARS);
for(i=0; i<NPARS; i++){
for(j=0; j<NPARS; j++){
printf("%lf \t", covold[i*NPARS+j]);
printf("%lf \n \n");
return 0;
ifstream data(f.c_str(), ios::in);
if (!data) {
cerr << "File " << f << " could not be opened." << endl;
exit(1);
for(int i = 0; i < nrow; i++)
for(int j = 0; j < ncol; j++)
data >> mtrx[i*ncol+j];
} // end of function fReadMtrx
The node in Matlab:
covold=load('COVFILE.txt');
meanold=load('MEAN.txt');
theta=load('thetacan.txt')';
weightold = 144; npars=72;
% Recursive form of covariance matrix
covold= ((weightold-1)/weightold)*covold + ...
(1/(1+weightold))* ((theta - meanold)*(theta-meanold)');
fcov = fopen('matlabcov.txt', 'wt');
for i=1:npars
for j =1:npars
fprintf(fcov, '%0.9f \t', covold(i,j));
end
fprintf(fcov,'\n');
end
fclose(fcov);
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Anas,
Current version of Intel MKL robust covariance estimator does not support streaming mode.
I just wonder if you investigated the reasons of why your covariance matrix fails the Cholesky decomposition? Do you work with the real data which may result in (tiny) negative eigenvalue of the covariance matrix? If so, what is output of the MKL Lapack pstf2 routine which does Cholesky decomposition with the full pivoting? If the issue is related to numerical aspects, would use of more robust decomposition such as SVD help? Another thought is to investigate presence of the outliers in your dataset. Have you run MKL Summary Stats algorithm for detection of outliers?
Thanks, Andrey
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Anas,
I wonder if you evaluated algorithms for covariance matrix computation available in Statistical component of Intel MKL and compared their output against Matlab? In MKL we support several methods for computation of covariance/correlation. Fast and single pass methods are among them. The library also allows re-using the mean estimate obtained earlier instead of its computation during evaluation of covariance - "user mean" method supports this use model.
Andrey
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Andrey! Thanks for the help.
The first time I computed the covariance matrix and the mean the results between Matlab and C were similar. I wanted to compute the covariance matrix and the mean sequentially but I didn't know how to do that with MKL so I tried to compute it by myself. Also do you know if MKL has a routine to force the covariance matrix to me positive define? I think I could do that with the routine of the robust covariance matrix but the first time I compute the covariance matrix the data are 144 and the parameters 72.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Anas,
Can you please clarify what you mean by computation of the covariance matrix and the mean sequentially? Does it mean that you compute the average first, and compute the covariance after that, and computation of the covariance relies on the pre-computed mean (in other terms, you need two pass approach for computation of the covariance matrix)?
Answering your second question - yes, In Statistical component of Intel MKL we provide the algorithm for stabilization of the correlation matrix. The input to the algorithm is the symmetric matrix which is not positively definite, and the output is the matrix which is "close" to the original and is positively semi-defined. The method VSL_SS_METHOD_SD, spectral decomposition method for parameterization of a correlation matrix is responsible for this type of the computations. Please, see additional details in Summary Stats application notes, http://software.intel.com/en-us/node/497944
Thanks, Andrey
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
By saying sequentially I mean:
for t =145 :T
I have available t-1 observations and I need to simulate from a d-dimensional Normal distribution with mean the vector theta and variance covariance matrix the current empirical estimate of the covariance matrix.
end
Each time I add a new observation so, instead of estimate each time the covariance matrix from the beginning I use a recursive formula for the covariance matrix. As you said I compute the mean first, and compute the covariance after that, and computation of the covariance relies on the pre-computed mean.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Anas,
MKL covariance algorithm supports the streaming way of the processing; that is, when the data comes in blocks the covariance algorithm can update the estimate using it previous value and the latest observation data. Please, have a look at the section "Processing Data in Blocks" in Summary Stats Application notes, http://software.intel.com/en-us/node/497946
Computational flow is mostly the same as in case of the processing of the whole dataset, but you need additionally to initialize covariance matrix with zeros (or other meaningful for you numbers), and register in the library the array which would hold the accumulated weights.
The file vslddataprocessinginblocks.c available in examples/vslc of MKL installation tree contains the example which shows how to do progressive computation of estimates.
Please, let me know, if you need more details.
Andrey
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I didn't find the file vslddataprocessinginblocks.c but I read the notes about Summary Statistics Application. I tried to compute the covariance matrix and the mean sequentially. If I have understood right the blocks must be of the same size. So I thought to compute the covariance matrix (C) and the mean (M) of the first data and then to use the recursive form and to initialize the mean and the covariance matrix with C and the mean with M. Then I say that the blocks have size 1.
Let a be the matrix that I want to find the covariance matrix.
a = 1 4 7 10 13 1 3
2 5 8 11 10 1 3
3 6 9 12 4 2 2
The true covariance matrix is
21.2857 17.5238 9.7143
17.5238 15.9048 11.8095
9.7143 11.8095 14.6190
and the true mean is
5.5714 5.7143 5.4286
( I found it with Matlab.)
I computed the covariance matrix and the mean of the first 4 data. So as initial covariance matrix I chose
15 15 15
15 15 15
15 15 15
and initial mean
5.5000 6.5000 7.5000.
The result I got is wrong. I would like to ask you if you could help me to understand what I have done wrong.
The C code is:
#include <mkl.h>
#define DIM 3 /* Task dimension */
#define N 1 /* Number of observations */
#define NBLOCK 4 /* Number of blocks */
int main()
VSLSSTaskPtr task; /* SS task descriptor */
int i, j;
double x[DIM]={13, 10, 4}; /* Array for dataset */
double W[2]; /* Array of accumulated weights */
MKL_INT p, n, xstorage = VSL_SS_MATRIX_STORAGE_ROWS; ;
MKL_INT covstorage = VSL_SS_MATRIX_STORAGE_FULL;
int status, block_idx;
/* Initialize variables used in the computation of mean */
p = DIM; n = N;
double mean[3] = {5.5 ,6.5 ,7.5};
double cov[DIM*DIM] = {15, 15, 15, 15, 15, 15, 15, 15, 15};
W[0] = 4.0; W[1] = 16.0;
/* Create task */
status = vsldSSNewTask( &task, &p, &n, &xstorage, x, 0, 0 );
status = vsldSSEditCovCor( task, mean, cov, &covstorage, 0, 0 );
/* Initialize task parameters */
// status = vsldSSEditTask( task, VSL_SS_ED_MEAN, &mean );
status = vsldSSEditTask( task, VSL_SS_ED_ACCUM_WEIGHT, W );
double theta[6]={1,1,2,3,3,2};
/* Compute the mean estimate for block-based data using SS one-pass method */
for( block_idx = 1; block_idx<=NBLOCK; block_idx++)
status = vsldSSCompute( task, VSL_SS_COV, VSL_SS_METHOD_1PASS );
//GetNextDataBlock( x, N );
for( i=0; i<3; i++){
x = theta[i + block_idx - 1];
printf(" covariance estimate:\n");
for ( i = 0; i < p; i++ ){
for( j = 0; j < p; j++ ) printf("%lf \t", cov[i*p+j]);
printf("\n");
printf(" mean estimate:\n");
for ( i = 0; i < p; i++ ) {
printf("%lf \n", mean);
/* De-allocate task resources */
status = vslSSDeleteTask( &task );
return 0;
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Anas,
I made several modifications in your example. Among them
- number of blocks is set ot 3 as you process three additional blocks
- both elements in the array W are set to 4 as you do not assign weights to observation vectors what means that each vector is assigned weight 1, by default; this means that accumulated weights/squares of weights are both equal to 4.
- modified copy loop as shown x = theta[i + DIM*block_idx]; and re-worked the major computation loop.
Please, have a look.
#include <mkl.h>
#define NBLOCK 3 /* Number of blocks */
int main()
int i, j;
double x[DIM]; /* Array for dataset */
p = DIM; n = N;
double cov[DIM*DIM] = {15.0, 15.0, 15.0, 15.0, 15.0, 15.0, 15.0, 15.0, 15.0};
W[0] = 4.0; W[1] = 4.0;
/* Create task */
double theta[]={13.0,10.0,4.0,1.0,1.0,2.0,3.0,3.0,2.0};
for( block_idx = 0; block_idx<NBLOCK; block_idx++)
for( i=0; i<DIM; i++)
printf("\n");
return 0;
The library allows you to avoid copy operation, and you just need to register the address of the next vector (block) in the library as shown below
status = vsldSSEditTask( task, VSL_SS_ED_OBSERV, theta+block_idx*DIM );
Generally, the library does not require you to provide the blocks of the equal size on each iteration. You just need to register the address of the next block in the library using the proper editor as one above (or just copy the data to the same address given the array has sufficient room to store the data) and properly modify number of observations.
Please, let me know if you have more questions.
Andrey
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Andrey!
Thank you very much for your help. Can I use this routine with the Robust Estimation of Covariance Matrix/ Mean? And if I do I replace this
status = vsldSSEditCovCor( task, mean, cov, &covstorage, 0, 0 ); status = vsldSSCompute( task, VSL_SS_COV, VSL_SS_METHOD_1PASS );
with this
status = vsldSSEditRobustCovariance( task, &covstorage, &nparams, params, mean, cov ); status = vsldSSCompute( task, VSL_SS_ROBUST_COV, VSL_SS_METHOD_TBS );
I ask you this because sometimes the covariance matrix is not positive define and the Cholesky decomposition fails. I read how to Parametrize a Correlation Matrix ( http://software.intel.com/en-us/node/497944 ) but it is about the correlation matrix.
Thanks again for the help.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Anas,
Thanks, Andrey
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Andrey. I followed your suggestions and I found out that the covariance matrix is symmetric but has negative eigenvalues. The problem I face is:
I want to simulate from a multivariate normal distribution. When I try to do it with Matlab everything works. Matlab uses the function cholcov to factorize the covariance matrix. The description of this function is:
function [T,p] = cholcov(Sigma,flag) %CHOLCOV Cholesky-like decomposition for covariance matrix. % If SIGMA is not positive definite, T is computed from an eigenvalue % decomposition of SIGMA. T is not necessarily triangular or square in % this case. Any eigenvectors whose corresponding eigenvalue is close to % zero (within a small tolerance) are omitted. If any remaining % eigenvalues are negative, T is empty.
I wrote a similar code in C but the factorization still fails. I tested my code with a small matrix and it is correct. I noticed that the eigenvectors/eigenvalues are different and so I think this is the reason. For example the first 5 elements of the first row using Matlab is:
-0.178640536933692 -0.171785233742083 0.003536032250076 0.215976356770781 0.047220738084061
and using the function LAPACKE_dsyev( LAPACK_ROW_MAJOR, 'V', 'U', n, a, lda, w ); is:
-0.128768 -0.028550 0.101975 -0.159201 -0.099586 .
The first five eigenvalues with C is -0.000004 -0.000004 -0.000004 -0.000004 -0.000003
and with Matlab
1.0e-12 *
-0.286064537835538 -0.254355758173010 -0.227684048920343 -0.211110573333574 -0.126353300135388.
I would like to ask you if I am using a wrong function to calculate the eigenvalues.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I found why the eigenvalues are not the same. It is because the covariance matrix calculated by Matlab and my C are similar but not identical. I would like to ask you if there is a way to find the weighted covariance matrix using this type
I think intel by default computes the covariance matrix divided by one minus the sum of squares of the weights.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Anas,
What is maximal absolute difference between elements of the matrices calculated in C and Matlab?
Yes, [d|s]syev function can be used to calculate eigen-values and, optionally, eigen-vectors of real symmetric matrix.
Answering your question about weighted covariance matrix: yes, Intel MKL covers this case as well. To calculate, weighted covariance matrix you need to provide array w of weights (non-negative floating-point numbers) assigned to vectors of your data matrix on the stage of the task construction: status = vsl[d|s]SSNewTask(&task, p, n, xstorage, x, w, indices);
or later, on the stage of setting parameters of the task: status = vsldSSEditTask(task, VSL_SS_ED_WEIGHTS, w);
The library returns unbiased estimate of the covariance matrix by dividing by B=W[0] - W[1] / W[0] where W[0] = sum {w(i), i=1,...,n} and W[1]= sum { w(i) * w(i), i=1,...,n}, n is number of observation vectors. In specific case when all w(i)=1, B=n-1. I believe Matlab version of covariance algorithm also applies the same approach :"C = cov(x) or C = cov(x,y) normalizes by N – 1, if N > 1, where N is the number of observations. "
If for some reasons you need another scaling factor, you can do this by using one of approaches below:
- calculate weighted covariance matrix with MKL as described above and use the scaling factor you need: for example multiply elements of the covariance matrix by B / W[0]
- calculate cross-product matrix VSL_SS_CP with MKL (also see "Mathematical Notation and Definitions" section in Summary Statistics Chapter in MKL Manual), and normalize it by the factor you need: for example, multiply all elements of the cross-product matrix by 1 / W[0].
Please, let me know, if you have additional questions
Andrey
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Andrey!
I computed the weighted covariance matrix with the routine of MKL and the maximal absolute difference between elements of the matrices calculated in C and Matlab is 4.9964e-07.
I think that the problem is with the way I compute eigenvectors. The weighted covariance matrix is of size 72x72. When I compute the eigenvetors of the maxtrix cov(1:8, 1:8) the results are similar:
C:
LAPACKE_dsyev (row-major, high-level) Example Program Results
Eigenvalues
-0.000054 1.427183 10.758958 52.897686 74.362089 136.253008 194.688280 350.1769
50
Eigenvectors (stored columnwise)
0.515386 0.159367 -0.286849 -0.669017 0.235831 0.099866 -0.294156 -0.164305
0.405829 0.150487 0.037140 0.077003 -0.548590 -0.441154 0.265017 -0.489435
0.285582 0.123878 0.309648 0.362790 0.128867 0.698942 0.011544 -0.412722
-0.046588 0.166949 -0.275717 0.392072 0.671869 -0.415776 -0.026933 -0.339432
-0.013717 -0.799634 -0.464384 0.020837 -0.051799 0.167395 0.135810 -0.308485
0.505743 -0.166573 0.123221 0.014151 0.321240 -0.059478 0.644899 0.422453
0.454486 -0.335560 0.153900 0.367831 -0.062415 -0.210976 -0.637902 0.257939
0.153075 0.359133 -0.699940 0.353858 -0.256212 0.240732 0.033498 0.328240
>>MATLAB
>> [U,D] = eig(Sigma(1:N,1:N))
U =
0.5154 0.1594 -0.2868 -0.6690 0.2358 0.0999 -0.2942 -0.1643
0.4058 0.1505 0.0371 0.0770 -0.5486 -0.4412 0.2650 -0.4894
0.2856 0.1239 0.3096 0.3628 0.1289 0.6989 0.0115 -0.4127
-0.0466 0.1670 -0.2757 0.3921 0.6719 -0.4158 -0.0269 -0.3394
-0.0137 -0.7996 -0.4644 0.0208 -0.0518 0.1674 0.1358 -0.3085
0.5057 -0.1666 0.1232 0.0142 0.3212 -0.0595 0.6449 0.4225
0.4545 -0.3356 0.1539 0.3678 -0.0624 -0.2110 -0.6379 0.2579
0.1531 0.3591 -0.6999 0.3539 -0.2562 0.2407 0.0335 0.3282
D = -0.0000 1.4272 10.7589 52.8977 74.3620 136.2530 194.6883 350.1770
When I compute the eigenvetors of the maxtrix cov(1:9, 1:9) the first two columns are not similar anymore.
Weighted Covariance Matrix:
56.3916 -5.4461 21.0892 14.2106 11.8545 -57.3334 4.1571 -32.3024 15.2373
-5.4461 146.8146 25.6903 55.8912 51.6568 -48.5882 -60.4055 -57.3076 -16.0235
21.0892 25.6903 135.4878 22.4742 59.0458 -61.5392 -51.8902 -22.3711 -37.1519
14.2106 55.8912 22.4742 106.5974 25.5030 -34.2876 -11.3883 -56.1283 33.8852
11.8545 51.6568 59.0458 25.5030 44.1879 -31.5876 -49.2822 -24.6174 -28.2669
-57.3334 -48.5882 -61.5392 -34.2876 -31.5876 151.8341 -41.1556 43.9437 -35.8322
4.1571 -60.4055 -51.8902 -11.3883 -49.2822 -41.1556 116.4474 25.3112 64.5246
-32.3024 -57.3076 -22.3711 -56.1283 -24.6174 43.9437 25.3112 62.8033 -4.9204
15.2373 -16.0235 -37.1519 33.8852 -28.2669 -35.8322 64.5246 -4.9204 84.1603
Eigenvalues:
-0.000057 0.000023 10.019260 21.561065 54.367911 78.008325 148.580208 240.545184 351.642481
0.464211 0.286119 -0.253666 -0.138729 -0.688994 -0.161246 -0.197438 0.236286 -0.153382
0.369437 0.207801 0.075771 -0.113015 0.137812 0.547265 0.479130 -0.106393 -0.492387
0.266667 0.116239 0.350457 -0.079392 0.401792 -0.271112 -0.597882 -0.122541 -0.422891
-0.102864 0.247021 -0.323244 0.270853 0.259084 -0.606857 0.415646 0.193232 -0.324115
0.153243 -0.749641 -0.529701 -0.054766 0.048735 0.005765 -0.098534 -0.136057 -0.316769
0.537240 -0.085383 0.121956 -0.028795 0.011747 -0.373801 0.306880 -0.544996 0.396636
0.497502 -0.142657 0.019880 0.474899 0.280762 0.162971 -0.060372 0.561165 0.286842
0.066352 0.405470 -0.608450 -0.322486 0.415615 0.164747 -0.207056 -0.103762 0.321663
0.048082 -0.215439 0.191162 -0.744958 0.153808 -0.198146 0.225448 0.489173 0.082056
>>MATLAB
0.0888 -0.5380 -0.2537 -0.1387 -0.6890 -0.1612 -0.1974 0.2363 -0.1534
0.0522 -0.4206 0.0758 -0.1130 0.1378 0.5473 0.4791 -0.1064 -0.4924
0.0065 -0.2908 0.3505 -0.0794 0.4018 -0.2711 -0.5979 -0.1225 -0.4229
0.2676 0.0015 -0.3232 0.2709 0.2591 -0.6069 0.4156 0.1932 -0.3241
-0.7518 0.1424 -0.5297 -0.0548 0.0487 0.0058 -0.0985 -0.1361 -0.3168
-0.2827 -0.4648 0.1220 -0.0288 0.0117 -0.3738 0.3069 -0.5450 0.3966
-0.3206 -0.4063 0.0199 0.4749 0.2808 0.1630 -0.0604 0.5612 0.2868
0.3501 -0.2151 -0.6084 -0.3225 0.4156 0.1647 -0.2071 -0.1038 0.3217
-0.2176 0.0372 0.1912 -0.7450 0.1538 -0.1981 0.2254 0.4892 0.0821
D = -0.0000 -0.0000 10.0193 21.5611 54.3679 78.0083 148.5802 240.5452 351.6425
When I compute the eigenvetors of the maxtrix cov(1:10, 1:10) the first three columns are not similar anymore.
56.3916 -5.4461 21.0892 14.2106 11.8545 -57.3334 4.1571 -32.3024 15.2373 -12.0170
-5.4461 146.8146 25.6903 55.8912 51.6568 -48.5882 -60.4055 -57.3076 -16.0235 23.2106
21.0892 25.6903 135.4878 22.4742 59.0458 -61.5392 -51.8902 -22.3711 -37.1519 18.9639
14.2106 55.8912 22.4742 106.5974 25.5030 -34.2876 -11.3883 -56.1283 33.8852 23.7952
11.8545 51.6568 59.0458 25.5030 44.1879 -31.5876 -49.2822 -24.6174 -28.2669 7.0779
-57.3334 -48.5882 -61.5392 -34.2876 -31.5876 151.8341 -41.1556 43.9437 -35.8322 10.3152
4.1571 -60.4055 -51.8902 -11.3883 -49.2822 -41.1556 116.4474 25.3112 64.5246 -18.7151
-32.3024 -57.3076 -22.3711 -56.1283 -24.6174 43.9437 25.3112 62.8033 -4.9204 -27.0933
15.2373 -16.0235 -37.1519 33.8852 -28.2669 -35.8322 64.5246 -4.9204 84.1603 -23.3719
-12.0170 23.2106 18.9639 23.7952 7.0779 10.3152 -18.7151 -27.0933 -23.3719 48.1540
Eigenvalues
-0.000074 -0.000007 0.000069 14.383856 47.663747 56.938335 81.601720 150.841004 244.580663 356.869088
-0.481945 0.238691 -0.296280 -0.058899 -0.224708 -0.661197 -0.103156 -0.197077 -0.250968 0.139158
-0.286255 0.310447 -0.042790 0.117771 0.076327 0.153157 0.575001 0.442529 0.085 446 0.492887
-0.121402 0.321346 0.153835 0.274036 0.222007 0.314981 -0.307425 -0.595861 0.091624 0.420454
0.138479 0.147031 -0.175741 -0.457146 0.261977 0.083460 -0.565433 0.428019 -0.190057 0.323579
-0.414390 -0.691821 0.256296 -0.343323 0.189936 -0.044647 0.049596 -0.119904 0.111411 0.314305
-0.444848 0.216592 0.258796 0.073873 0.130422 -0.097410 -0.323642 0.299107 0.570384 -0.369756
-0.389791 0.198062 0.340298 -0.282169 -0.207850 0.437734 0.042489 -0.017191 -0.535665 -0.299269
-0.229001 0.004085 -0.678527 -0.201394 0.422988 0.276068 0.171912 -0.215680 0.105579 -0.322852
-0.179141 -0.272966 -0.026355 0.632220 0.416494 -0.041068 -0.145469 0.238512 -0.479687 -0.098481
-0.213996 -0.287199 -0.382463 0.235318 -0.614075 0.390115 -0.291176 0.139765 0.138791 0.131193
>>MATLAB
U =
-0.3277 0.4663 -0.2286 -0.0589 -0.2247 -0.6612 -0.1032 -0.1971 -0.2510 0.1392
-0.0137 0.3774 -0.1938 0.1178 0.0763 0.1532 0.5750 0.4425 0.0854 0.4929
0.2155 0.2775 -0.1350 0.2740 0.2220 0.3150 -0.3074 -0.5959 0.0916 0.4205
-0.0207 -0.0933 -0.2501 -0.4571 0.2620 0.0835 -0.5654 0.4280 -0.1901 0.3236
-0.2651 0.1150 0.7953 -0.3433 0.1899 -0.0446 0.0496 -0.1199 0.1114 0.3143
0.1233 0.5371 0.0902 0.0739 0.1304 -0.0974 -0.3236 0.2991 0.5704 -0.3698
0.2028 0.4973 0.1361 -0.2822 -0.2078 0.4377 0.0425 -0.0172 -0.5357 -0.2993
-0.6354 0.0646 -0.3240 -0.2014 0.4230 0.2761 0.1719 -0.2157 0.1056 -0.3229
-0.2132 0.0332 0.2464 0.6322 0.4165 -0.0411 -0.1455 0.2385 -0.4797 -0.0985
-0.5194 -0.0149 0.0671 0.2353 -0.6141 0.3901 -0.2912 0.1398 0.1388 0.1312
D = -0.0000 -0.0000 -0.0000 14.3839 47.6638 56.9384 81.6017 150.8410 244.5806 356.8691
The eigenvectos change when the eigenvalues are close to zero. I did some search and found that MATLAB uses LAPACK routines to compute eigenvalues and eigenvectors: If the matrix is Real Symmetric it uses the dsyev (http://nf.nci.org.au/facilities/software/Matlab/techdoc/ref/eig.html)
Isn't it strange that the results are different?
Matlab computes eigenvectors with this way:
[V,D] = eig(A) returns matrix V, whose columns are the right eigenvectors of A such that A*V = V*D. The eigenvectors in V are normalized so that the 2-norm of each is 1. Method: 'chol'Computes the generalized eigenvalues of A and B using the Cholesky factorization of B.
The code I used is:
/* Parameters */
#define N 9
#define LDA N
/* Main program */
int main() {
/* Locals */
MKL_INT n = N, lda = LDA, info;
/* Local arrays */
double w;
double a[LDA*N];
fReadMtrx("weightedcov.txt", a, N, N);
/* Executable statements */
printf( "LAPACKE_dsyev (row-major, high-level) Example Program Results\n" );
/* Solve eigenproblem */
info = LAPACKE_dsyev( LAPACK_ROW_MAJOR, 'V', 'U', n, a, lda, w );
/* Check for convergence */
if( info > 0 ) {
printf( "The algorithm failed to compute eigenvalues.\n" );
exit( 1 );
/* Print eigenvalues */
print_matrix( "Eigenvalues", 1, n, w, 1 );
/* Print eigenvectors */
print_matrix( "Eigenvectors (stored columnwise)", n, n, a, lda );
exit( 0 );
} /* End of LAPACKE_dsyev Example */
/* Auxiliary routine: printing a matrix */
void print_matrix( char* desc, MKL_INT m, MKL_INT n, double* a, MKL_INT lda ) {
MKL_INT i, j;
printf( "\n %s\n", desc );
for( i = 0; i < m; i++ ) {
for( j = 0; j < n; j++ ) printf( " %lf", a[i*lda+j] );
printf( "\n" );
if (!data) {
exit(1);
Thank you very much for helping me.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Anas,
per my discussion with Intel MKL Lapack team, we have few comments related to your question on eigen solver output:
- you see the different eigen-vectors that correspond to eigen-values close to zero. We can consider those eigen-values as multiple up to some tolerance. In this case you can't expect that corresponding eigen-vectors are uniquely defined: if Au = lambda u and Av = lambda v, than linear combination of u and v is the eigen-vector corresponding to the same value, A (c1 u + c2 v) = lamba (c1 u + c2 v). It defines the sensitivity of resulting eigen-vectors to floating-point errors/perturbations in the matrix.
- Thus, it does not make big sense to compare eigen-values/vectors returned by different algorithms. More reliable way to evaluate correctness of the algorithm is calculation of the quality metrics || A - U Lambda U^t || / || A || and |U^t U - I|| where A=U Lambda U^t is full eigen-decomposition of the matrix A of size n x n. Both metrics should be small ~O( n * eps ). Additional ways to evaluate correctness of the eigen-solver exist, but it makes sense to start with the one described above.
Please, let me know if this answers your question
Andrey
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Andrey!
I appreciate your help. Thank you very much.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
