7303 Discussions
Error in PARDISO ( numerical_factorization) error_num= -987
Andreas_Fabri__Geome
I try to solve a sparse system with pardiso, using the evaluation version of the Beta of the MKL
on Windows 7, 64.
As I have to enable out-of-core if necessary I initialize the parameters as follows:
m_piparm[0] = 1; // No solver default
m_piparm[1] = 2;
m_piparm[9] = 0;
m_piparm[17] = -1;
m_piparm[20] = 1;
m_piparm[26] = 1;
m_piparm[59] = 1; // out off core if necessary
Here is the trace of the pardiso run. Any help is appreciated, and if necessary
I could dump the sparse symmetric matrix in a file and make it available.
Andreas Fabri
=== PARDISO is running in Out-Of-Core mode, because iparam(60)=1 and there is no
t enough RAM for In-Core ===
================ PARDISO: solving a symm. posit. def. system ================
Summary PARDISO: ( reorder to reorder )
Times:
Time fulladj: 1.618750 s
Time reorder: 48.901887 s
Time symbfct: 6.202610 s
Time malloc : 1.084790 s
Time total : 85.589953 s total - sum: 27.781916 s
Statistics:
< Parallel Direct Factorization with #processors: > 1
< Numerical Factorization with Level-3 BLAS performance >
< Linear system Ax = b>
#equations: 2797565
#non-zeros in A: 23286826
non-zeros in A (): 0.000298
#right-hand sides: 1
< Factors L and U >
#columns for each panel: 128
#independent subgraphs: 0
< Preprocessing with state of the art partitioning metis>
#supernodes: 1300322
size of largest supernode: 3421
number of nonzeros in L 604905508
number of nonzeros in U 1
number of nonzeros in L+U 604905509
Percentage of computed non-zeros for LL^T factorization
0 %
1 %
44 %
Fseek failed
*** Error in PARDISO ( numerical_factorization) error_num= -987
PARDISO Internationalization error! Message -987 is unknown
Summary PARDISO: ( factorize to factorize )
Times:
Time A to LU: 0.000000 s
Factorization: Time for writing to files : 0.000000
Factorization: Time for reading from files : 0.000000
Time numfct : 0.000000 s
Time malloc : 0.053992 s
Time total : 105.836084 s total - sum: 105.782091 s
Statistics:
#equations: 2797565
< Factors L and U >
gflop for the numerical factorization: 886.436031
The error code is : -4
Gennady_F_Intel
Tierry,
We 've checked and reproduced the issue on our side. Actually the problem affects dynamiclly linked libraries. The cause of the problem has been found and will fix soon. I will inform when the fix will available.
thanks agian for the report.
--Gennady
Thierry_LE_SOMMER__E
Sorry for not replying earlier to your previous message.
I'm glad to hear that you managed to reproduce this problem.
Thierry
Gennady_F_Intel
we have already fixed that issue but I am not aware when this fix will available for external customer. in any case - many thanks for the good test case :).
--Gennady
Gennady_F_Intel
Hi Thierry,
the problem has been fixed in the latest version of MKL 10.2 Update 7. Could you please check if the problem is still there and let us know.
--Gennady
