7300 Discussions
FFT, DftiCommitDescriptor error: Module not found
Serjio
tried to use FFT from MKL and got an error.
I'm using Win10, VS2019 and mkl 2021.2.0 from intel.oneapi.win.BaseKit.package.
I run official one-dimensional In-place FFT example ( see basic_dp_complex_dft_1d.c ) in c++ console application and defined an error.
status = DftiCommitDescriptor(hand); // Error is here
 Here it is an error message - "Exception adress 0x76C2A6E2 (KernelBase.dll) in test.exe: 0xC06D007E: Module not found ".
Could please help me to fix this problem?
MRajesh_intel
When you set debug to x86 mode, automatically 32-bit implementation of the compiler is added to the environment.
If not done automatically set the path to:
PATH=C:\Program Files (x86)\Intel\oneAPI\compiler\2021.2.0\windows\redist\ia32_win\compiler;C:\Program Files (x86)\Intel\oneAPI\mkl\2021.2.0\redist\ia32;%PATH%
I hope this answers your query. Please let us know if you have any other issues. If not, can we proceed further to close this thread?
Rajesh.
MRajesh_intel
Can you please share the Visual Studio version and the settings used? In the meanwhile, try setting the environment details in Debugging section, in the Configuration Properties section to:
PATH=C:\Program Files (x86)\Intel\oneAPI\compiler\2021.2.0\windows\redist\intel64_win\compiler;C:\Program Files (x86)\Intel\oneAPI\mkl\2021.2.0\redist\intel64;%PATH%
Let us know if you face any issues.
Rajesh.
Serjio
Hi, Rajesh.
My Visual Studio version: Community 2019 v16.9.4
It seems to me, that my project needs to be configured correctly.
When I specify the environment details in Debugging section, in the Configuration Properties section to:
I get an error when debugging starts:
"Error while starting the application (0xc000007b)"
So, please help me set up Visual Studio to use Intel OneMKL.
Let's start by setting the environment variables as I haven't set any variables since installing Intel oneAPI.win.BaseKit.
This is how my Visual Studio settings look like:
Do I need to use the setvars.bat script from Intel oneAPI to set system variables in Windows?
Sorry there are so many questions))
MRajesh_intel
Also, try setting the Debug setting to x64 and let us know if that works.
Rajesh.
Serjio
If I set "Solution Platforms" to x64, then the FTF calculation works fine!
Thanks, Rajesh.
But... if I need to do my project in x32 mode? How to make debug in x32 mode?
MRajesh_intel
Rajesh.
MRajesh_intel
Thanks for accepting as a Solution.
As this issue has been resolved, we will no longer respond to this thread. If you require any additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day.
Rajesh
