I am trying to integrate cluster_sparse_solver into my application, however, I am confused by this in the documentation:
Note
Most of the input parameters (except for the pt, phase, and comm parameters and, for the distributed format, the a, ia, and ja arrays) must be set on the master MPI process only, and ignored on other processes. Other MPI processes get all required data from the master MPI process using the MPI communicator, comm.
I interpret this as saying if rank=0, then all input parameters need to be defined. But if rank > 1, then you can input NULL values? I tried doing that as shown in this pseudo code below. But I keep getting "ERROR during symbolic factorization: -1" when I run with np > 1. With np 1 it runs correctly, but only on one host.
int main() { mpi_stat = MPI_Init( &argc, &argv ); mpi_stat = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); comm = MPI_Comm_c2f( MPI_COMM_WORLD ); if ( rank < 1 ) { read_input_file(); assemble_i_ia_ja(); call_cluster_sparse_solver(); } else { int i; long long pt[64]; for(i=0;i<64;i++){pt=0;} double *aupardiso=NULL; ITG *icolpardiso=NULL,*pointers=NULL,iparm[64]; ITG maxfct=1,mnum=1,phase=12,nrhs=1,*perm=NULL,mtype, msglvl=0,error=0,*irowpardiso=NULL, neq; double *b=NULL,*x=NULL; FORTRAN ( cluster_sparse_solver, ( pt, &maxfct, &mnum, &mtype, &phase, neq, aupardiso , pointers , icolpardiso, perm, &nrhs, iparm, &msglvl, b, x, &comm, &error )); }
The function call_cluster_sparse_solver contains this code:
int mpi_stat = 0; int comm, rank; mpi_stat = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); comm = MPI_Comm_c2f( MPI_COMM_WORLD ); FORTRAN ( cluster_sparse_solver, ( pt, &maxfct, &mnum, &mtype, &phase, neq, aupardiso , pointers , icolpardiso, perm, &nrhs, iparm, &msglvl, b, x, &comm, &error ));
You are correct, if you don't use distributed format then pointer can be set as null. Can you provide iparm data that you use on master process?
Alex
On master process ( rank = 0 ), iparm is set only as follows:
ITG iparm[64];
iparm[0]=0;
then cluster_parse_solver is called as follows:
Is this correct, or should iparm be different ? I can try and create a simple example code that reproduces this issue .
yes, can you provide the example?
Alex
Just following up if someone had a chance to run my example code that reproduces the issue I am facing?
Unfortunately, I am still facing difficulty in how to call cluster_sparse_solver when rank > 0 . Can someone share some simple example so I can compare with my code? The documentation states:
How exactly do all the input parameters need to be initialized for the non-master process? Here is what I tried which seems to keep giving segmentation fault:
if ( rank > 0 ) { comm = MPI_Comm_c2f( MPI_COMM_WORLD ); /* Matrix data. */ MKL_INT n=NULL; MKL_INT *ia=NULL; MKL_INT *ja=NULL; float *a=NULL; MKL_INT mtype=NULL; MKL_INT nrhs=NULL; float *b=NULL, *x=NULL, *bs=NULL, res=0.0, res0=0.0; /* RHS and solution vectors. */ void *pt[64] = { 0 }; /* Cluster Sparse Solver control parameters. */ MKL_INT *iparm = NULL; MKL_INT maxfct=NULL, mnum=NULL, phase=NULL, msglvl=NULL, error=NULL; /* Auxiliary variables. */ float ddum=0.0; /* float dummy */ MKL_INT idum=NULL; /* Integer dummy. */ phase = 11; printf ("got here 11"); cluster_sparse_solver ( pt, &maxfct, &mnum, &mtype, &phase, &n, &a, ia, ja, &idum, &nrhs, iparm, &msglvl, &ddum, &ddum, &comm, &error ); phase = 22; printf ("got here 22"); cluster_sparse_solver ( pt, &maxfct, &mnum, &mtype, &phase, &n, a, ia, ja, &idum, &nrhs, iparm, &msglvl, &ddum, &ddum, &comm, &error ); phase = 33; cluster_sparse_solver ( pt, &maxfct, &mnum, &mtype, &phase, &n, a, ia, ja, &idum, &nrhs, iparm, &msglvl, &ddum, &ddum, &comm, &error ); phase = -1; cluster_sparse_solver ( pt, &maxfct, &mnum, &mtype, &phase, &n, a, ia, ja, &idum, &nrhs, iparm, &msglvl, &ddum, &ddum, &comm, &error ); }
I finally figured it out after isolating and testing each input individually. These have to be set to 1, not NULL:
I would suggest updating the documentation as this is not accurate:
It took me many weeks to figure out, but here's what worked for me for the ranks > 0:
Hopefully Intel can update their provided examples to include something like this. The examples they have are great for tiny matrixes. But to modify it for a real application is quite a confusing process. An example for the dummy_cluster_sparse_solver would save people many weeks of work
void dummy_cluster_sparse_solver() {
int mpi_stat = 0;
int comm, rank;
mpi_stat = MPI_Init( '', 1 );
if ( rank == 0 ) { return; }
/* Matrix data. */
MKL_INT n;
MKL_INT *ia;
MKL_INT *ja;
MKL_INT mtype;
MKL_INT nrhs;
double *a, *b, *x;
long int *pt;
long int pt_real_sym_indefinite[64] = { 0 };
long int pt_real_symmetric[64] = { 0 };
long int pt_real_non_symmetric[64] = { 0 };
pt = pt_real_symmetric;
MKL_INT iparm[64] = { 0 };
MKL_INT maxfct, mnum, msglvl, error;
double ddum; /* float dummy */
MKL_INT idum; /* Integer dummy. */
MKL_INT phase;
MKL_INT matrix[2] = { 0 };
MPI_Bcast ( matrix, 2, MPI_LONG_LONG, 0, MPI_COMM_WORLD );
phase = matrix[1];
while(( phase != 1 )){
printf ( "\nEntering phase %i in while loop for matrix %i\n", phase, matrix[0] );
FORTRAN ( cluster_sparse_solver , ( pt, &maxfct, &mnum, &mtype,
&ddum,&ddum, &comm, &error ));
if ( matrix[0] == -2 ) memcpy( pt_real_sym_indefinite, pt, sizeof(pt_real_sym_indefinite));
if ( matrix[0] == 1 ) memcpy( pt_real_symmetric, pt, sizeof(pt_real_symmetric));
if ( matrix[0] == 11 ) memcpy( pt_real_non_symmetric, pt, sizeof(pt_real_non_symmetric));
phase = matrix[1];
if ( matrix[0] == -2 ) pt = pt_real_sym_indefinite;
if ( matrix[0] == 1 ) pt = pt_real_symmetric ;
if ( matrix[0] == 11 ) pt = pt_real_non_symmetric;
} // end while
mpi_stat = MPI_Finalize();
exit(0);
} // end function
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
